Oil Pressure
Old Jun 1, 2008 | 06:11 PM
k24556's Avatar
k24556
Default Oil Pressure
The oil pressure gage is pegged at 80psi, and the DIC says the oil pressure is 130psi. Is this a sign of a bad pressure sensor?
2000 convert, MN6.
Old Jun 1, 2008 | 06:34 PM
rws.1's Avatar
rws.1
Those are the exact symtoms....
You can either replace or re locate
Old Jun 1, 2008 | 06:36 PM
rws.1's Avatar
rws.1
Here is a great DIY for replacing the sensor...
http://forums.corvetteforum.com/show...t=oil+pressure
Old Jun 1, 2008 | 09:08 PM
k24556's Avatar
k24556
Thanks for the help! We went out for a spin tonight, and everything worked fine. At first, the gage pegged, and The DIC went to 120. Then ever so slowly, the reading of the DIC and the gage came down to 45psi. I must be on the verge of sensor failure. The link you sent will be a great help. Besides the sensor, are there any other parts needed? I didn't notice a gasket between the intake and the heads, but I presume there is one.
Old Jun 2, 2008 | 12:25 AM
C5 LS7's Avatar
C5 LS7
Sender is bad, if it goes completely, it will leak oil everywhere.
To Oil Pressure
