Need some help with O2 Sensors
Had the resignators removed last fall. They were welded onto the pipes. A straight piece was installed in it's place. Since then I keep getting 2 codes.
P1133 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1-8
P1153 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank2 Sensor 1-B
What exactly does this mean? I was thinking an exhaust leak, but I don't hear any leaks!
Thanks in advance
You either have ...
* An exhaust leak
* The wiring to the O2 sensors is disconnected from them
* The wiring has been over heated or rubbed and exposed wires are shorting/grounding.
* Contaminated or incorrect fuel (what are you running the car on??)
* The sensors themselves are damaged and need replacement
You either have ...
* An exhaust leak
I'll have to get it up on a rack and visualy check. I always run the highest octane fuel I can buy. 97 or 98 octane.
The Corvette is NOT a Flex Fuel Vehicle. The C5 MUST NOT be run on E85 ...... you can run E10 (90 percent gasoline) but E85 is a "contaminated" fuel. Way too much alcohol.
You may have already destroyed your catalytic converters .... Switch to PREMIUM UNLEADED gasoline immediately. You are at risk of doing serious damage to the engine running E85 ... the fuel injectors cannot deliver enough fuel (E85 has only about 75 percent of the "energy" of gasoline ... so the engine needs substantially more fuel to get a stochiometric burn) ....... your engine is running dangerously lean at high RPM or WOT runs.
Hopefully switching back to Premium gasoline will fix your cats .... if not, each cat at GM list price is well over $1,000.00
You may have already destroyed your catalytic converters .... Switch to PREMIUM UNLEADED gasoline immediately. You are at risk of doing serious damage to the engine running E85 ... the fuel injectors cannot deliver enough fuel (E85 has only about 75 percent of the "energy" of gasoline ... so the engine needs substantially more fuel to get a stociometric burn) ....... your engine is running dagerously lean at high RPM or WOT runs.
I have a couple of sources of 100 octane UNLEADED that I use to raise my octane when I go to the track (to prevent engine damage ... not for better performance) but I haven't seen 97 at a pump.
Well, get her up on the lift and let us know what you find ... good luck ...
C5 (any year ) DO NOT have resonators! So,,,,,most likely, you had a CAT removed! That would account for your your issue!
BC
BC
You're a GOD ..... that NEVER occured to me .... I just assumed (stupid thing to do) he was talking about his mufflers ...... duh ......
BC
http://www.sunocoinc.com/site/Consum...UnleadedFuels/
I'd recommend that you either switch to the pump fuel ... or the 100 octane .... and try that for a while ..... the OFF-ROAD formulations are not blended to take the cats into account......
Otherwise .... put the car on a lift and see what is going on .... but I'm suspicious your choice of fuel is contributing to your problem .....if you even have cats on the car.....
The Corvette exhaust is a three piece system ... and no welding is required to replace "parts".
The first part are the exhaust manifolds themselves. Directly below the exhaust manifold is a flange that bolts the catalytic converter section in place. That section runs all the way to just in front of the rear axle. Again there is a flange and bolted to that is the muffler section ... the pipes that climb over the rear axle and go into the mufflers and tthen the exhaust tips.
The Magnaflow systems offer two choices .... one is a bolt-in replacement of the rear muffler section with Magnaflow mufflers (part 15660 ... see http://www.magnaflow.com/02product/parts/15660_lg.jpg ). The other choice is a 2 piece system that requires welding .... one piece is the section behind the cats (part 15437 in above link) which welds to the stock cats or the magnaflow cats (part 93988 .... see http://www.car-sound.com/02product/d...irectfit=93988 ) which can weld to the above magnaflow exhaust or the stock exhaust.
It kinda sounds like you cut out the Magnaflow catalytic converters ..... would explain why you got the codes after cutting out the "resignators" .......
If you need more than 93 Octane,,,,,,God bless you! Your in to the 9.000 9.990 time frame 1/4 mile time frame,
BC
Anyway, they just called and said the O2 sensors are probably bad, so they are replacing them.
If that doesn't work, what's next? The ECM?
Confused. God knows I am!
Now to fix the drivers seat grinding noise when it moves forward.
Thanks for everyones help. This forum rocks.
