Steering PROBLEM; Advice please!!!
Old Jun 4, 2008 | 01:08 AM
BodaciousBlue's Avatar
BodaciousBlue
Default Steering PROBLEM; Advice please!!!
When I'm driving at high speeds my steering tightens up as if I had no power steering. I know I have the variable speed control in my vette. But the steering becomes so tight during high speeds it takes most of my strength to turn the wheels. Frightening at times. When the vette slows down to 65 miles per hour the steering is very light and normal. But the tightness at high speeds (85) does not happen on a consistent basis.
I thought it might be the tensioner that the serpentine belt spins on. Any vette owners out there had this similar experience? Any suggestions?
Reuben aka BodaciousBlue
Old Jun 4, 2008 | 05:35 AM
BlackZ06's Avatar
BlackZ06
I would check to see if you have any DTC set, especially in the EBCM. The EBCM controls the Magnasteer function on the car. As vehicle speed increases the Magnasteer valve allows less and less steering assistance from the power steering pump. The system uses vehicle speed (calculated from the Wheel Speed sensors) and steering input (calculated using the Steering Wheel Position sensor) to determine power assist levels.
If I had to take a guess ..... your SWPS is getting flakey .....
Old Jun 4, 2008 | 11:36 AM
BodaciousBlue
Thanks BLACK Z06, I'll check those items you suggested.
Old Jun 7, 2008 | 11:54 AM
BodaciousBlue
Any other suggestions my vette buddys???
Old Jun 7, 2008 | 03:17 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
power steering pump failing. Mine did it at the track intermittantly in corners.
Old Jun 10, 2008 | 01:08 PM
BodaciousBlue
Thanks for the response John Shiels I do appreciate everyones' response!
Old Jun 10, 2008 | 10:30 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
If you're not throwing any codes, the power steering pump is good and there is sufficient fluid in the reservoir, then the only variable I can think of since its a 1999 C5 is that you have contaminated fluid, which begs the question, "when was the last time you had the system flushed and added fresh synthentic power steering fluid?" Frankly, I would put money on a failing power steering pump. Mike
To Steering PROBLEM; Advice please!!!
