Need help.....Lighting Problem
Old Jun 4, 2008 | 12:06 PM
Georgian's Avatar
Georgian
Default Need help.....Lighting Problem
I changed all the lights on the interior to blue LED's, the installation went smooth and fairly quickly and all the lights work....when the cars not running. When you start the car all the lights shut off including the lights behind the speedo etc, and i mean all the lights. If anyone has any idea why this is happening help would be great, I'm going to take it all apart again and check everywire hopefully i find something.
Old Jun 5, 2008 | 11:47 AM
g.t.o.boy's Avatar
g.t.o.boy
All of the lighting is controlled by the body module and the dic, these are computer controlled and setup for differant voltage then leds draw. You could wire in resistors for all the lights, or do the easy and correct way of setting it up the way the engineers designed it, and put the oem lights back in.
