Electrical Gurus....door lock issues
Today, I go out to run some errands, and found things still aren't right. Here's what I have:
A) Both the fobs, as well as the driver's side door switch, will lock the passenger door and arm the security system. Neither fob, nor the driver's door switch, will lock the driver's door;
B) If manually locked, both fobs and/or the door switch will unlock the driver's door and disarm the security system;
C) the key will lock/unlock the driver's door, and the inside lock lever works the lock. (The mechanical connection is OK)
D) I checked the "DIC", and there are no codes showing at all. I tried another relearn and nothing changed.
Any thoughts??
Knock on wood, at least the gas gauge is functioning!!
http://forums.corvetteforum.com/show....php?t=1606865
