Torque converter Lockup question.........
Old Dec 21, 2001 | 12:56 AM
FreddyG's Avatar
FreddyG
Default Torque converter Lockup question.........
What exactly is meant when a TC locks up? What are the advantages and disadvantages? I read that you can have the PowerloaderII lock up the converter in 3rd and 4th, if this is true, would it be worth it to do with a stock TC?
Old Dec 21, 2001 | 02:28 AM
Nilla Ice's Avatar
Nilla Ice
Default Re: Torque converter Lockup question......... (LuvmyC5)
In simple terms...your A4 is putting more rearwheel horsepower down...imagine a non-locked up torque converter as a clutch that is never fully engaged. The stock converter can not handle it under WOT, but it does lock up under partial throttle...ever feel what seems like a 4th shift around 50ish MPH? That's the stocker locking up.
Advantages are more efficiency and better MPH like the M6s get. Disadvantages are under WOT it is hard on the converter and the tranny. If the converter is locked up too soon the car will bog and actually slow down in the quarter.
Tony
Old Dec 21, 2001 | 09:36 AM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
Some torque converters have so little slippage that lock-up is not necessary.
Old Dec 21, 2001 | 11:18 AM
Nilla Ice's Avatar
Nilla Ice
Default Re: Torque converter Lockup question......... (Buckmaster)
Also, if it doesn't lock up the rpms remain higher reducing gas mileage significantly and also it is harsh on the tranny if it does not lock up.
Just to clarify, under partial throttle that is true.
Old Dec 21, 2001 | 02:59 PM
FreddyG's Avatar
FreddyG
Thanks guys. I understand the lock-up thing now. So, can you lock-up the TC through the PCM in 3rd and 4th? Can you feel the difference when it locks up or is it just noticeable on a dyno or timeslip?
Old Dec 21, 2001 | 03:56 PM
Austrian Vette's Avatar
Austrian Vette
You really can feel the difference.
You can lock up tha TC with a siple switch also (like me), but I would only recommend it on a Vigilant.
On a SY 3500 for example you will feel no difference if you lock it up as this TC is very efficient as is.
Michael
To Torque converter Lockup question.........
