'98 traction control light on.
Old Jun 5, 2008 | 07:13 PM
Konstantin's Avatar
Konstantin
Default '98 traction control light on.
does anyone know the price of ABS/Traction control module from a dealer ? i phoned but parts dept is already closed, need the price tonight.
thanks if anyone can help.
- Kons
Old Jun 5, 2008 | 08:23 PM
BlackZ06's Avatar
BlackZ06
First ... which EBCM do you have .... the one in the rear (by the differential .... early 1998) or the one in the engine compartment (later 1998) ???
Also, do you have option JL4 (Active Handling) ???
Second, have you displayed the DTC data ... it may not be the EBCM ... a wheel speed sensor problem turns on the same light ... display the data and post here ......
Go here if you don't know how to get the data ...
https://www.corvetteforum.com/techti...D=26&TopicID=1
Old Jun 5, 2008 | 08:28 PM
Konstantin's Avatar
Konstantin
i am buying a car, i do not own it yet, and i am not sure if i can get the actual codes. just thinking how expencive can it get ? do not know where it is located either. can i tell by the vin and production date, if so i can get it.
- Kons
Old Jun 5, 2008 | 08:32 PM
BlackZ06's Avatar
BlackZ06
- Kons
Give me 5 minutes and I'll get you a "worst case" number ....
Old Jun 5, 2008 | 08:40 PM
jarsdad1's Avatar
jarsdad1
...and, of course, you'll have the seller reduce the car's price by that amount plus an hour labor.
Old Jun 5, 2008 | 08:44 PM
BlackZ06's Avatar
BlackZ06
The EBCM is the same for all 1998 ... part number 9367071 is currently GM list price $576.69
There are 3 possible BPMV
Mounted in the engine bay is part number 12530740 and lists at $2,095.75
Mounted in the rear is either part number 10417038 ($2,054.66) or part number 12527809 ($2,158.43)
So worst caase is $2,735.12 plus labor (and if the BPMV needs replacing you will most likely need to have the dealer or other service location with a Tech2 programmer do the work ... a Tech2 is required to bleed the brake fluid through the new BPMV.) ... I'd figure 5 hours labor would be what a dealer would estimate.
I didn't notice where you are located ... these are US prices ..... Canada and other countries have their own pricing ... part numbers will be the same.
Old Jun 5, 2008 | 08:55 PM
BlackZ06's Avatar
BlackZ06
OK ... I see you're in Canada .... you could order from this guy so long as you are willing to pay by credit card .... also plug those part numbers in and you will see that he sells them cheaper than GM list ... but you have to add shipping.
http://www.gmpartshouse.com/
He does ship to Canada
http://www.gmpartshouse.com/faq.html#international
Old Jun 5, 2008 | 11:09 PM
Konstantin's Avatar
Konstantin
awesome, thanks guys.
To '98 traction control light on.
