differential seal plate o-ring
Old Jun 8, 2008 | 11:09 AM
verano29's Avatar
verano29
Default differential seal plate o-ring
I'm currently working on a diff/converter swap. I'm replacing the o-ring but should I be using some RTV in addition to this o-ring? I didn't see anything in the service manual about doing this but I have heard that some do this? What did you guys do?
Old Jun 8, 2008 | 11:26 AM
Patches's Avatar
Patches
I lubed the O-ring a bit to keep it supple but did not use RTV. No issues at all through 0-100F temp swings and no leaks at all. IMHO, if you try to mask the O-ring failure by trying to seal with RTV, you're putting off the inevitable repair. I would rather know sooner than later if the O-ring is not doing it's job.
I have replaced the diff in both my C5's and neither has a leak anywhere. They are both '02's.
Old Jun 8, 2008 | 11:54 AM
hightest's Avatar
hightest
I used dow corning valve and o-ring grease to hold the o-ring in place, as well as for lube. No issues.
Old Jun 8, 2008 | 12:55 PM
vettenuts's Avatar
vettenuts
If you are talking about the one between the tranny and differential, I used the differential lube for lubricant. Don't use RTV whatever you do.
Old Jun 8, 2008 | 12:56 PM
verano29's Avatar
verano29
Thanks for the input guys, I'll just make sure its well lubricated when I install it.
To differential seal plate o-ring
