Leaky wheel at TPMS - Help!!!
Old Jun 8, 2008 | 04:13 PM
tvette007's Avatar
tvette007
Default Leaky wheel at TPMS - Help!!!
I purchased a used set of C6 Z06 wheels for my C5. I had new tires mounted on the rims, but my left rear tire leaks where the the TPMS come through the rim. I had new seal kits installed on all the wheels, but this one leaks pretty bad.
Question is...If I install a larger o ring (larger than the one in the kit) do you think it would solve the problem? Has anyone else run into this issue and what did they do to correct it?
Old Jun 8, 2008 | 04:33 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Not to be insulting, but is the retaining nut tight?
Old Jun 8, 2008 | 04:47 PM
tvette007's Avatar
tvette007
Yes, the nut it tight. I just wondering if a thicker o ring would stop the leaking. It leaks down pretty quick. I had them mounted yesterday and the tire shop must has put some kind of sealer on it to prevent it from leaking, but it failed by the time I go home last night. Tire is now flat..
Old Jun 8, 2008 | 05:07 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
When you use the C6 wheels OEM or even replicas ,also use the OEM C6 TPMS grommets as the holes are a little bigger on those wheels. They will seal the TPMS better
Old Jun 8, 2008 | 05:16 PM
tvette007's Avatar
tvette007
Thanks. I'll try that. I pulled the tire off and am taking it to the tire shop tomorrow. I will suggest they do that. Strange thing is...all the other tires are fine, but I will definitely try that!
Old Jun 8, 2008 | 09:24 PM
Cart99's Avatar
Cart99
Common problem. Easily sealed with a larger o-ring. Go to Home Depot and buy a #9 o-ring (or maybe #8, don't recall which).
Old Jun 8, 2008 | 10:09 PM
tvette007's Avatar
tvette007
Perfect! Thanks. I was goiong to do that, but I wasn't sure which size to get. Thanks for the help. Nice ride!!
Old Jun 9, 2008 | 12:34 PM
jovette's Avatar
jovette
Believe it's # 9 from home depot. That's what I used when I mounted new tires on my '00 coupe last summer. The #9s are bigger / thicker than the OEM O-Rings.
To Leaky wheel at TPMS - Help!!!
