Help! What do these codes mean?
Old Jun 11, 2008 | 09:16 PM
sandra1956's Avatar
sandra1956
Default Help! What do these codes mean?
I have check engine light on.
I read the codes...but do no t know what they mean?
Would anyone be able to help me by telling what they mean and how do I fix?
10 PCM PO442 H C
AO-LDCM B2282 H
B2284 H
U1064 H
U1255 H
U1016 H
U1096 H
AI-RDCM B2283 H
B2284 H
U1255 H
U1064 H
U1016 H
U1096 H
BO RFA 1000 H
1064 H
1096 H
1255 H
I hope someone can give me some help!!!
or tell me where I can buy a book that will tell me what these and any other future codes mean.
thanks!! Sandra
Old Jun 11, 2008 | 09:27 PM
c5streak's Avatar
c5streak
The p0442 is most likely either a loose or defective gas cap. Make sure it's on tight. Clear the code, drive it and see if it resets.
Everything else looks like it could be from a low or dead battery at one time. Clear them all and give it a try.
Here's a sight for the code list.
http://www.stengel.net/diccodes.htm
Old Jun 12, 2008 | 10:07 PM
sandra1956's Avatar
sandra1956
Thank you for the codes ..C5 streak! you're the best!!!
The "old" history codes were from a dead battery several months ago. The one about the fuel cap.. will come back eventually, its gone now but I know we have a small seeping of the fuel. I notice it most when we fill up the car and let it sit in the garage a few hours... whee.. fumes will get to ya'.
Need to get it to the shop and that taken care of.
but thanks again for your help!
Sandra
Old Jun 13, 2008 | 02:01 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sandra
Getting to know your C5 is something that will save you a LOT of money and make you a LOT HAPPIER with the car. Here is a small piece I put together to help people get to know their cars:
READING YOUR Engine Diagnostic Codes
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes)
If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, C or ;H. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present;
press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET
To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
These are the absolute best C5 Diagnostic Trouble Code (DTC) explanation web sites!!!
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.\
Here is another very good site:
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Use the reset button to clear ALL your DTCs and then take the car for a drive and see if any come back. GET THAT FUEL ISSUE FIXED!
Hope this helps.
Bill C
Old Oct 14, 2008 | 04:59 AM
FiberglassFan's Avatar
FiberglassFan
This page in now dead
To Help! What do these codes mean?
