Paint on a LS-6 Intake
Old Jun 12, 2008 | 01:14 PM
Kevin Conway's Avatar
Kevin Conway
Default Paint on a LS-6 Intake
Has anyone ever painted there stock intake and if so how did it come out. Also if this can be done what paint do you reccommend. Pis would also be useful. THANKS.
Old Jun 12, 2008 | 02:13 PM
rpm462's Avatar
rpm462
I think Chip did his own. His forum handle is Willfulone and his vendor site is CCA on the left column. Here's a link to his website with a picture of his engine bay.
http://www.customcorvetteaccessories...ehosekits.html
Old Jun 12, 2008 | 07:48 PM
hotmerc's Avatar
hotmerc
The painting works well, but you can get them powdercoated and they look great. This is done in almost chrome.
Old Jun 12, 2008 | 09:36 PM
Kevin Conway
O>K guys, thanks for the input.
Old Jun 12, 2008 | 09:55 PM
MR1911's Avatar
MR1911
Rattle can engine paint works well its all in the prep , did mine over 2 years ago and it still looks good .
Old Jun 12, 2008 | 10:08 PM
6 Kids's Avatar
6 Kids
St. Jude Donor '06
Painting holds up very well when applied correctly.
Old Jun 13, 2008 | 12:14 AM
sami85L98's Avatar
sami85L98
Wow the fire paint thingy is really hot i can feel it...Great looking.
Old Jun 13, 2008 | 07:42 AM
dheck's Avatar
dheck
I use white Krylon as a base and then paint over it with just about anything, Hi Temp paint works the best. I have also used a clear plastic primer and then used hi temp paint.
Old Jun 13, 2008 | 09:17 AM
nickolbag's Avatar
nickolbag
Curious.....does the paint cause the intake to retain any heat?
Old Jun 13, 2008 | 09:19 AM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
and now for something completely different hydocarbon graf
Old Jun 13, 2008 | 12:22 PM
MR1911's Avatar
MR1911
Not sure if its much different with the plastic intake but back in the old days we would always paint the bottom with white paint to reflect heat away from the intake and either leave the top raw or paint it black to dissipate heat . Since these plastic ones are suppose to run cooler to begin with I don't think it would matter. I did mine the old way white on the bottom but did do a color on top, but never checked to see if there was any difference .
Old Jun 13, 2008 | 07:30 PM
fixvet's Avatar
fixvet
Used Duplicolor on mine. My intake barely gets more than just warm to the touch....never hot! I followed some detailed instruction from ls1tech.com. Prep is the most important step. Good luck!
To Paint on a LS-6 Intake
