VHP Fan Controller Question
Old Jun 12, 2008 | 02:50 PM
EStreeter's Avatar
EStreeter
Default VHP Fan Controller Question
Does anyone know if the VHP fan controller will override a PCM fan setting. My car has a tune and the fans to come on at 189 degrees.
If I bought the VHP fan controller and wanted the car to run a little hotter for street use would the controller override that setting or do the fans have to be set back to stock?
Old Jun 12, 2008 | 05:36 PM
vettenuts's Avatar
vettenuts
The VHP will control the fans if set lower than the PCM. You need to reset the PCM if you want to use the controller. This way it is fail safe, if the controller fails the fans will still come on at the PCM settings.
