Can you pull Check engine codes through the DTC?
Old Dec 22, 2001 | 11:56 AM
Phil97SVT's Avatar
Phil97SVT
Default Pulling codes -> Can anyone tell me what these codes mean?
Topic says it all.
Phillip
[Modified by Phil97SVT, 6:29 PM 12/22/2001]
Old Dec 22, 2001 | 11:58 AM
oceanaire's Avatar
oceanaire
Default Re: Can you pull Check engine codes through the DTC? (Phil97SVT)
Yes, Hold options button down and press fuel 4 times. This will put you in the diagnostic mode and show you any set codes. Eric
Forgot to mention, your key has to be on. :yesnod:
[Modified by oceanaire, 10:59 AM 12/22/2001]
Old Dec 22, 2001 | 12:05 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Can you pull Check engine codes through the DTC? (oceanaire)
I pulled the codes and there are at least 15 codes in 5 different sections. Is there a web page listing all of the codes?
Phillip
Old Dec 22, 2001 | 12:08 PM
oceanaire's Avatar
oceanaire
Here's some: http://www.c5-corvette.com/IPC_Codes.htm I'm sure there is a complete listing out there somewhere.
Hope this helps, Eric :)
Old Dec 22, 2001 | 12:41 PM
Phil97SVT's Avatar
Phil97SVT
OK well I checked it out and here is what I found. None really seemed pressing but a few were thought provoking.
PCM 1-P0410 air system - ??
SDM <== didnt see this one on the web page
U1016h
B1001
LDCM
B2282 - battery #1 fault - ??
B2284 - Battery #2 fault
RDCM
same codes as LDCM
U1016
SCM-
b0846/b0851 -Battery 1 and 2 out of range
B2192 - Seat forward switch shorted to gnd
b2605 - seat front vert position sensor failure
b2607 - seat horizontal position sensor failure
RFA-
u1016 loss communication with PCM
u1064 loss of communication with DCM
u1096 loss communication with IPC
u1255 serial data line malfunction
Phillip
To Can you pull Check engine codes through the DTC?
