98 corvette automatic trans help
Old Jun 14, 2008 | 08:33 PM
ronald49's Avatar
ronald49
Cruising
Default 98 corvette automatic trans help
how do you put trans fluid in 1998 corvette coupe automatic trans is slipping had slight leak i guess it need new gasket and trans fluid how do you put fluid in it which side is drain plug on help getting codes p0756 and
Old Jun 14, 2008 | 11:30 PM
SUNNYD 95's Avatar
SUNNYD 95
The place where you put the fluid into the trans is were you drain it from. The drain plug is also the fill hole.
Its located on the left side (drivers side)
Also its a good idea to change the filter at this time.
Old Jun 15, 2008 | 04:08 AM
ronald49's Avatar
ronald49
Cruising
wheres that front of car or back
Old Jun 15, 2008 | 01:02 PM
thetaxman's Avatar
thetaxman
take it to a mechanic
you are not qualified to work on cars
Old Jun 15, 2008 | 01:56 PM
MikeV's Avatar
MikeV
If you have to ask, you may want to take it to a mechanic. I am not being an A hole but its not for the faint of heart to do this. First off all four wheels have to be up on stands and level. The engine has to be running. The trans temp has to be within certain temps and you have to run it thru the gears. Now check it by removing the plug on the side and fill it until it runs out. Dam I wish it just had a dip stick!
Good Luck
Mike V
Old Jun 15, 2008 | 05:03 PM
4DRUSH's Avatar
4DRUSH
You should fill out your profile. Their could be someone right down the street that could help you. Maybe me???????
Old Jun 16, 2008 | 09:16 AM
SUNNYD 95's Avatar
SUNNYD 95
WTF
Old Jun 17, 2008 | 12:08 AM
Mark-44's Avatar
Mark-44
Good Luck
Mike V
I agree... Been there, done that. It gets easier after a few times, but very messy and hot. It may be too late to put the new gasket on to save the transmission.
Old Jun 17, 2008 | 12:12 AM
lucky131969's Avatar
lucky131969
Take it to a qualified mechanic partner.
To 98 corvette automatic trans help
