MAF questions
Old Jun 14, 2008 | 08:48 PM
Blow Torch's Avatar
Blow Torch
Default MAF questions
Can I use a MAF from a 2000-2001 on my 98? (are the plugs different?)
Although it's been discussed before, is there ANY issues with running a "descreened" MAF as long as it is tuned?
What's a good price for a used MAF?
Old Jun 15, 2008 | 12:22 AM
jedblanks's Avatar
jedblanks
In general, cars with a screened MAF stock should stay that way. That's what I've seen and heard on here.
If you run a 2001+ MAF on a 98, you'll need an adapter harness (paceperformance?). The IAT is integrated into the MAF, so the harness will adapt to plug into your IAT plug and MAF plug.
I have a descreened older MAF if you need one ($40). With the type plug you need.
