New water pump, Redesign ???
Old Jun 15, 2008 | 05:31 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default New water pump, Redesign ???
I put a new water pump on and my old 160* thermostat doesnt fit in the housing. Its an AC Delco unit so I was wondering if there was a redesign?
Old Jun 15, 2008 | 06:40 PM
vettenuts's Avatar
vettenuts
I thought I read that all new water pumps are the LS2 pump, which don't use the old stat design from the LS1.
Old Jun 15, 2008 | 09:49 PM
Corvette-Chris
St. Jude Donor '08
Ok thats what I needed to know. Thanks VN !!! I guess Ill just order a stat for an LS2 ?
Old Jun 15, 2008 | 11:04 PM
Russ K's Avatar
Russ K
You will also need the thermostat housing for the 2004 & up LSx engine.
Russ kemp
Old Jun 15, 2008 | 11:07 PM
Corvette-Chris
St. Jude Donor '08
It all comes as one piece if I am not mistaken
Old Jun 16, 2008 | 12:06 AM
Russ K's Avatar
Russ K
The 2004 & newer LSx engine thermostat is separate from the housing.
Russ Kemp
Old Jun 16, 2008 | 08:15 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Russ Kemp
GM parts is only stocking the new design water pump now.
It does require a seperate thermostat and housing.
To New water pump, Redesign ???
