BCM help
Old Jun 16, 2008 | 10:38 PM
redman0204's Avatar
redman0204
Default BCM help
Where is the Bcm located in the car .
Old Jun 16, 2008 | 10:57 PM
BlackZ06's Avatar
BlackZ06
If you don't know ... my first question is "why do you want to know" ??????
The BCM is located in the passenger footwell ..... peel the carpeting back from the top directly under the dash, then open the floorboard directly below the dash. There are two critical componenets there .... the one on the right holds fuses and relays, the silver box on the left is the BCM.
Old Jun 17, 2008 | 01:01 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
There's one important thing that I might add. This area should be completely dry. If you find any evidence of moisture, the A/C evaporator drain tube is probably clogged.
To BCM help
