My check engine light keeps flashing (No codes stay) which means I’m misfiring. I ran into this earlier in April and took my car to the stealer ship. They saw that my stock spark plug wires had melted in certain points due to the heat of my aftermarket headers. So I replaced all of the wires with new Magnecor ignition wires (& also added Kool Socks). This fixed the initial problem. Now my car is misfiring again and I can’t figure out why. I took out all my Magnecor wires and reinstalled them again just to make sure they were all secure but she is still misfiring. After the car cools the misfiring seems to go away but the second it heats up it comes right back.
Anyone have any ideas as to what else could be causing me to misfire? Any help would be great.
I hate to state the obvious about checking the plugs. Inspect around the engine in the dark with it running to see if you see any arcing. Just because the wires aren't melted, doesn't mean they are good.
I have the same problem . going to try msd wires. u might want to check the ground wires like i did. There is a post on here somewhere that has a pic. where all the ground wires are. good luck. to ya
I just checked that and couldn't see any arcing in the wires...
