newbie-dead battery
As for why the battery died, there are a few gremlins that others have experienced, such as lumbar motor working, visor vanity mirrors not turned off, seat motor going on, mirror lights on, etc. This might involve some detecive work on your end, and it would probably be a good idea to do a drain test, there are some good threads on here about it. And of course you always start with verifying that the battery is in fact good, by having it load tested, and also that all the cables are clean and tight, at the battery, starter, alternator, and fuse block.
Good Luck
Close Out Panel - Front Bumper Fascia Lower
Removal Procedure
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the front fascia lower close out panel to wheelhouse panel bolts.
Remove the valance panel.
Remove the front fascia lower close out panel to fascia bolts.
Remove the close out panel.
Park/Turn Signal/Side Marker Lamp Bulb Replacement
Removal Procedure
Remove the front fascia lower closeout panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers. SEE ABOVE
Release the brake caliper cooling duct from the front fascia, and position the duct aside.
Remove the appropriate socket from the lamp assembly.
Remove the bulb from the socket.
Installation Procedure
Install the bulb to the socket.
Install the socket to the lamp assembly.
Position the brake caliper cooling duct to the front fascia and press the duct toward the fascia to secure.
Install the front fascia lower closeout panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers.
Lower the vehicle.
As a side benefit, with these and a floor jack, you can do oil changes and so on pretty easily. You need to floor jack to raise the back of the car, to level it for the oil to drain, but can jack from the rear diff jacking points just fine. My ramps cost me about $50, but have been a great purchase. Also allow an arthritic old man to change the oil on the wife's car, and on my DD GMC T15 Jimmy.
Congrats on the new car!
