Crazy signal
Old Jun 19, 2008 | 08:12 PM
redman0204's Avatar
redman0204
Default Crazy signal
Just had BCM installed at the stealership. now left siganl work's normal but right one move's like a bat out of hell in the rear and the front don't work at all .plus running light's work when lights are on but only left work's when there off WHAT UP thanks in advance
Old Jun 19, 2008 | 09:33 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Assuming these were all working before the BCM replacement, it sounds like they didn't do the RPO code upload properly. Why did you have the BCM replaced?
Old Jun 19, 2008 | 10:26 PM
peptoy's Avatar
peptoy
Dont know if its the same but... Had similar crazy turn signal issues. Turned out to be the multi function switch (turn signal switch).
See http://forums.corvetteforum.com/show....php?t=1988708
Your millage may vary.
Old Jun 19, 2008 | 11:35 PM
bestvettever's Avatar
bestvettever
Default Turn Signal Problems
Hi when a turn signal bulb is burned out, or inoperative, the other lights on that side will blink much faster. I suggest you check the right front signal bulb, socket and wire.
Good Luck
Old Jun 20, 2008 | 04:23 PM
redman0204's Avatar
redman0204
Default re crazy signal
Bulb works fine . just not when the flasher or turning signal is on and just in the right front .
Old Jun 21, 2008 | 04:06 PM
neokorros's Avatar
neokorros
i have same exact issue but did not have any work done previously. just started the other day outs nowhere.
~ nick
To Crazy signal
