How to remove differential fill plug?
Old Jun 21, 2008 | 04:20 PM
Oldvetter's Avatar
Oldvetter
Default How to remove differential fill plug?
Title says it all. I have an allen wrench that fits it. My 1998 has the ABS Brakes located behind the differential, making it hard to reach.
I tried a wrench on the allen wrench with another wrench on that one. Just bent the first wrench ! With this setup I can't get a hammer on any of the wrenches.
I was thinking of buying an allen wrench attached to a 3/8 inch drive socket, figured with extensions I could reach it.
Any other suggestions. Also thinking of letting the Dealer change it.
Old Jun 21, 2008 | 07:59 PM
Kurtomac's Avatar
Kurtomac
i just used the allen head sockets and an extension...cracked her loose no problem...just got the crappy autozone brand too i think
Old Jun 21, 2008 | 08:26 PM
Bill Dearborn's Avatar
Bill Dearborn
The ABS module is on the driver's side of the diff while the plug is on the passenger side. What is getting in the way?
Bill
Old Jun 21, 2008 | 09:06 PM
Oldvetter's Avatar
Oldvetter
Bill
Well there is something on the passenger side, maybe a pump?
I will try the allen head sockets and an extension, thanks Kurtomac.
Old Jun 22, 2008 | 02:13 AM
Dave68's Avatar
Dave68
That worked for me as well.
Good luck!
Old Jun 22, 2008 | 02:47 AM
thetaxman's Avatar
thetaxman
except my tools are snap-on
Old Jun 22, 2008 | 08:19 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Yeah, but you probably figured a way to write them off or depreciate them ( just had to do it )
Old Jun 22, 2008 | 10:30 AM
Kurtomac's Avatar
Kurtomac
haha i just figured I'll never use these again...why go expensive...bought the set of allen head sockets...work great ended up using them again....valley cover bolts, FAST intake bolts, Rear end....still holding up fine...All my tools are namebrand as well just not those...I prefer Kobalt tools, I bought them when they were made by snap on. My dad makes the broaches that cuts their tooling....ah and gearwreches are a must with these cars.
good luck
To How to remove differential fill plug?
