Clogged cats??
Old Jun 21, 2008 | 07:37 PM
Crabr1's Avatar
Crabr1
Default Clogged cats??
How can you tell if your cats are clogged,my car just started running bad again,think it might be the tune,but now I'm thinking maybe cats.I'm S/C'ed and when I get on it it goes to the 10lbs that I've always had but the exhaust sounds different and it has no power,I can feel its trying to go but something is holding it back?Waiting to get it back to the tuner but he's been real busy,maybe tommorrow,just waiting for him to call or pm me.
Old Jun 21, 2008 | 07:50 PM
FourG63 97GST's Avatar
FourG63 97GST
Open headers.
when mine was clogged, putting my hand at the tips an idle, there's a noticeable difference between airflow between the two but I also had an H-pipe. it also would hesitate when trying to rev it.
Old Jun 23, 2008 | 06:52 PM
Greg_E's Avatar
Greg_E
Are you running the spiral wound metal matrix type cats? A while back, one of the members posted pictures where he had blown the spiral wound metal out of the cat and it was unraveling in the X pipe. He also had an S/C. And yes, unbolting the headers should tell you if the cats or exhaust are plugged.
Old Jun 23, 2008 | 11:26 PM
Crabr1's Avatar
Crabr1
I just have the stockers on for now,I'm going for a dyno check/tune on Wednesday,so hopefully we will find out whas going on.
Old Jun 23, 2008 | 11:58 PM
FlyinNOE's Avatar
FlyinNOE
Mine failed about 15k after the blower was installed.
I was coming home from work one night at about 3 in the morning and gunned it to pass a truck. About 5000rpm it fell on it's face!
The funny thing was that it idled pretty well and below 1500 rpm drove normally. It was lumpy at idle and the Vac guage showed about 2" less than normal. After a dyno (it was 80 HP low) we figured it out. The left side cat was completely clogged.
I replaced both of them and have had no problems since (about 45k).
Hopes this helps.
Brian-
Old Jun 24, 2008 | 12:17 AM
Crabr1's Avatar
Crabr1
Hopes this helps.
So what were the other symptoms,mine does just what you are saying,when i get on it it feels like it wants to go but I can feel something holding it back,plus the exhaust sounds different,and i can feel it,it still gets 10lbs boost but the tach goes up real slow.I have about 7500mi since the S/C install.I'm going to see Tom on Wednesday,so hopefully he can figure it out,its hard to tell since i had a cam installed I've been having issues since.
Brian-
So what were the other symptoms,mine sounds like the same issue,when i get on it I still get my 10lbs but I can feel I'm down on power,and my exhaust sounds different.My tach also goes up real slow.i'm going to Toms on Wednesday so hopefully he can find out whats wrong.Its hard to tell since i had a cam installed I have been having issues.
Old Jun 25, 2008 | 09:58 AM
FlyinNOE's Avatar
FlyinNOE
Mine had the same issues yours does. It would make a TON of noise for almost no acceleration. I was actually scared to push it any harder than I needed to drive it to a dyno. I thought I had cracked a ring land on a piston or something but it made boost earlier than it should (because of the restriction).
If I had to guess I would bet it was one of your cats.
I do my own tune now and although rich is safe, overly rich can be hard on the cats. If you are tuning for a new cam and the air/ fuel ratio was off that might have done it. Maybe. But who knows, it could have been that cats time.
Because of the exhaust cross over (X or H pipe) it's impossible to tell which side is bad. The easiest thing to do is to drop down the H or X pipe and see if there is any cat left. If not, it is downstream wedged (near the muffler is where mine ended up) causing a restriction to end all restrictions.
Good luck and please keep us posted.
Brian-
Old Jun 25, 2008 | 12:27 PM
Crabr1's Avatar
Crabr1
Well it wasn't my cats afterall,it was as simple as a tiny pin hole in one of the new spark plug wire boots,my car started running bad maybe a week after the cam was installed and just got worse and worse,then the other day it got real bad,when I would get on it,so while on the dyno he looked at a cylinder graff and as it would get under load i would lose # 7&8,we pulled #8 plug and it looked fine,pulled the wire off #7 and he saw a little white spot on the boot,he cut the boot open and you could tell that was a problem,so anyway he put a new boot on and all that lost power is now back.
Old Jun 26, 2008 | 11:04 AM
FlyinNOE's Avatar
FlyinNOE
Good! I'm glad you got it fixed!
Thanks for keeping us posted. These posts help others!
Brian-
To Clogged cats??
