Cruise Control Issue
Old Jun 22, 2008 | 09:05 PM
chevybob's Avatar
chevybob
Default Cruise Control Issue
Hi,
I have a 1998 vette that has a fussy cruise control. It works fine on smooth pavement but dis-ingages on rougher roads. Very frustrating on long trips. Thanks for any input.
Bob
Old Jun 22, 2008 | 09:57 PM
clif's Avatar
clif
St. Jude Donor '09-'10
I think your active handling is canceling your cruise. When it sees different speeds on the wheels, it cancels the cruise control.
Old Jun 22, 2008 | 09:59 PM
Bill Dearborn's Avatar
Bill Dearborn
I agree. Turn off the Traction Control or Active Handling if you have it and see what happens.
Bill
Old Jun 23, 2008 | 12:12 AM
jrose7004's Avatar
jrose7004
Mine might disengage at anytime and not particularly on rough pavement. It will do it about once a day on a long trip.
Old Jun 24, 2008 | 10:58 PM
chevybob's Avatar
chevybob
I tried turning off traction control. Seemed to help but still dis-engaged.
Is this a wheel sensor issue? What all involves replacement fun?
thanks
Old Jun 25, 2008 | 12:24 AM
white90conv's Avatar
white90conv
It might be the clutch/brake switches are not adjusted quite right and a slight bump or body movement might cause the switch to disengage.
Old Jun 25, 2008 | 12:45 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Have you pulled the codes yet to see if its reporting anything?
Old Jun 25, 2008 | 12:58 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
There's one on the brake and one on the clutch pedal.
Old Jun 25, 2008 | 09:48 PM
Windshear's Avatar
Windshear
Mine will disengage if it perceives I have too much speed in a corner. Like not disengaging it on the clover leaf and off-ramps. I have never had it disengage other wise. It is connected to the yaw sensor or G meter. I run with the active handling off if the pavement is dry.
Old Jun 26, 2008 | 12:53 PM
DashingDaryl's Avatar
DashingDaryl
The C4 corvettes Cruise Control was a function of a vacum line. Are the C5's the same? Any chance one of your vacum lines has a slow leak which works during "easy Crusing" but not during the more complicated stuff?
Old Jun 26, 2008 | 01:27 PM
Mark W's Avatar
Mark W
Try pulling down on the plastic panel under the steering colum.There is a switch activated by the clutch that is mounted there and its tempermental.It thinks you are engaging the clutch and that turns off the cruis control.
Mark
Old Jun 26, 2008 | 03:03 PM
chevybob's Avatar
chevybob
I will put on 500 miles to Blooming Gold rally and test out some of these ideas. Thanks Bob
Old Jun 26, 2008 | 03:52 PM
white90conv
On the C5, cruise control is all electric.
To Cruise Control Issue
