DTC Code Meanings
Old Jun 23, 2008 | 09:49 PM
jski0236's Avatar
jski0236
Default DTC Code Meanings
Hi All,
First, what a great site for a newbie owner.
Also, before I start the car has a bad oil pressure sensor and a vacuum leak that will be fixed by the previous owner.
I have a check engine light issue and after seaching the site found how to get the codes along with a site to explain. Now, I need some help in determining what is wrong:
Codes
HVAC P0410HC
HO2S Circuit Insufficient Activity Bank 1 Sensor 2
I am unsure what this means.
HVAC BO361HC
Left Actuator Feedback Short to GND
Is this a headlight issue?
BO-RFA
U1096H, U1064H, U1061H
Class 2 Communication Malfunction
From what I understand these are history codes. What does class 2 communication malfunction?
C2120HC
TPM System Malfunction
My guess is this is the tire sensors as they do not work.
Thanks again for helping a newbie as I have already had a good learning exp from this site.
Jim
Old Jun 23, 2008 | 09:54 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Originally Posted by jski0236
Hi All,
Codes
HVAC P0410HC
HVAC BO361HC
BO-RFA
C2120HC
Jim
HVAC P0410HC
HVAC BO361HC
These 2 sound related and I don't have a manual, but I think they are both due to a short to ground ( wire rubbing the inside of dash framework or something) on the drivers side climate control actuator.
Old Jun 23, 2008 | 10:24 PM
Bill Dearborn's Avatar
Bill Dearborn
DTC P0410
Circuit Description
The secondary air injection (AIR) System is designed to lower exhaust emission levels on engine start up. The AIR pump runs for approximately 1 minute or until Closed Loop is attained.
The powertrain control module (PCM) commands the AIR pump relay ON by supplying a ground on the relay control circuit. This action energizes the AIR pump, forcing air into the exhaust stream. The PCM also commands the AIR vacuum control solenoid valve ON, which applies engine vacuum to the AIR shut-off valve. When vacuum is applied to the AIR shut-off valve, airflow from the AIR pump flows through the pipes/hoses to the exhaust check valves. The air then enters the exhaust stream. The air that is introduced into the exhaust system decreases the time it takes for the convertor to begin its process of converting the incomplete gases; reducing exhaust emission levels. When inactive, the check valves and the shut-off valve prevent airflow in either direction.
The PCM detects a system airflow problem by monitoring the heated oxygen sensors (HO2S) and Short Term Fuel Trim during normal AIR system operation. This is called a passive test. If the passive test indicates a pass, the PCM takes no further action. If the passive test fails or is inconclusive, the diagnostic will proceed with an intrusive or active test. The PCM will command the AIR system ON during closed loop operation under normal operating conditions. The active test will pass or fail based on the response from the HO2S. A lean HO2S response indicates that the secondary AIR system is functioning normally. An increasing Short Term Fuel Trim value also indicates a normally functioning system. The AIR diagnostic consists of the passive test and the active tests. The AIR diagnostic requires failure of the passive and active tests on 2 consecutive key cycles to illuminate the MIL and store a DTC. If the PCM detects that the HO2S and Short Term FT did not respond as expected on one of the engine banks, DTC P0491 or P0492 sets. If the PCM detects that the HO2S and Short Term FT did not respond as expected on both of the engine banks, DTC P0410 sets.
Conditions for Running the DTC
DTCs P0101, P0102, P0103, P0107, P0108, P0112, P0113, P0116, P0117, P0118, P0125, P0128, P0131, P0132, P0133, P0134, P0135, P0137, P0138, P0140, P0141, P0151, P0152, P0153, P0154, P0155, P0157, P0158, P0160, P0161, P0171, P0172, P0174, P0175, P0200, P0300, P0335, P0336, P0351, P0352, P0353, P0354, P0355, P0356, P0357, P0358, P0455, P0442, P0443, P0446, P0449, P1120, P1133, P1134, P1153, P1154, are not set.
The fuel level is more than 12.5 percent but less than 87.5 percent.
The engine is running for more than 30 seconds.
The mass air flow (MAF) is less than 23 g/s.
The air fuel ratio is 14.7:1.
The engine load is less than 40 percent.
The ignition voltage is more than 11.7 volts.
The vehicle speed is more than 15 km/h (25 mph).
The engine is operating in a Closed Loop for more than 15 seconds.
The engine speed is more than 850 RPM.
The engine coolant temperature (ECT) is between than -10°C and +110°C (14-230°F).
The intake air temperature (IAT) is between -10°C and +100°C (14-212°F).
The fuel system is operating in fuel trim cells 1, 2, 4, or 5.
The Short Term FT is between -4 and +4 percent.
The start-up engine coolant temperature is less than 70°C (158°F).
The engine is not operating in any of the following modes:
Power enrichment
Decel fuel cut-off mode
Catalyst over temperature
Conditions for Setting the DTC
When the AIR pump is commanded ON, during Closed Loop operation and the HO2S voltages do not decrease below 222 mV for 1.5 seconds.
AND
The Short-Term FT does not change more than a predetermined amount.
Action Taken When the DTC Sets
The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
Important
When commanding the AIR system ON with a scan tool the PCM will activate the AIR pump and the AIR solenoid. The fuel control system will then enter an open loop status. This action will allow fresh air to enter the exhaust stream and cause the front HO2S mV parameters to drop to near zero (0) mV. This would indicate a properly operating system. However if the AIR pump does not operate or there is no airflow from the pump entering the exhaust stream due to a leak in the system, the HO2S parameter may still drop below 100 mV. This is due to fresh air being drawn into the exhaust stream from the check valve operation and the opening of the shut-off valve. The HO2S will respond with a drop in mV readings as a result of this air leaning out the exhaust gases. The voltages may drop to below 100 mV but not approach the near zero (0) mV parameter.
An AIR pump which exhibits an exhaust noise through the pump may have an AIR solenoid or AIR shut-off valve stuck open. The Short Term Fuel Trims may indicate a higher than normal value. This condition may not set DTC P0410.
An AIR shut-off valve that has become inoperative and has shown indications of exhaust gases in the outlet port, or heat damaged hoses may indicate an exhaust check valve failure.
For any test that requires probing the PCM harness connector or probing a component harness connector, use the J 35616-A Connector Test Adapter Kit . Using this kit prevents damage to the component terminals and to the harness. Refer to Using Connector Test Adapters in Wiring Systems.
AIR Pump Relay Underhood Electrical Center Terminal Identification
Front of Vehicle
Left Side of Vehicle
Ignition 1 voltage
Battery positive voltage
Right Side of Vehicle
Pump Supply
Control
For an intermittent condition, refer to Intermittent Conditions .
The vacuum lines at the AIR solenoid cannot be reversed, this condition may hold the shut-off valve open continually.
An AIR solenoid leaking vacuum will hold the shut-off valve open an exhaust noise may be heard through the air cleaner. Fuel Trims values may also indicate a higher than normal value at idle. This DTC may not set.
Leaking exhaust check valves will leave traces of exhaust carbon in the AIR system, with a possibility of heat damage to the hoses and AIR shut-off valve.
An intermittent may be caused by any of the following conditions:
Low system air flow
Excessive exhaust system back pressure
Moisture, water or debris ingested into the AIR pump
Pinched, kinked, heat damaged, or deteriorated pipes/hoses or vacuum hoses.
Restrictions in the pump inlet, duct, or filter
Step
Action
values
Yes
No
Schematic Reference: Engine Controls Schematics
Connector End View Reference: Powertrain Control Module (PCM) Connector End Views or Engine Controls Connector End Views
1
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
2
Is DTC P0412 or DTC P0418 also set?
Go to Diagnostic Trouble Code (DTC) List
Go to Step 3
3
Turn ON the ignition, with the engine OFF.
Command the AIR pump relay ON and OFF with a scan tool.
Does the AIR pump turn ON and OFF with each command of the scan tool?
Go to Step 4
Go to Step 6
4
Start and Idle the engine until Closed Loop is achieved.
Observe the Long Term Fuel Trim parameter on the scan tool.
Is the parameter above the specified amount?
10%
Go to Step 5
Go to Step 17
5
Increase the engine speed to 1,500 RPM for 1 minute.
10%
Go to Fuel System Diagnosis
Go to Step 17
6
Inspect the AIR pump fuse.
Is the AIR pump fuse open?
Go to Step 7
Go to Step 11
7
Turn OFF the ignition.
Disconnect the AIR pump connector.
Connect a test lamp between the supply voltage circuit of the AIR pump harness connector and the ground circuit of the AIR pump at the harness connector.
Replace the AIR pump fuse.
Does the test lamp turn ON and OFF with each command of the scan tool?
Go to Step 40
Go to Step 8
8
Does the test lamp remain illuminated when the air pump relay is commanded ON and OFF with a scan tool?
Go to Step 9
Go to Step 10
9
Remove the AIR pump relay.
Does the test lamp remain illuminated?
Go to Step 32
Go to Step 37
10
Remove the AIR pump relay. Refer to Relay Replacement in Wiring Systems.
Test the battery positive circuit switched side of the AIR pump relay between the AIR fuse and AIR pump relay for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct a condition?
Go to Step 41
Go to Step 33
11
Connect a 20-amp fused jumper wire between the switched battery supply circuit and the AIR pump supply voltage circuit at the AIR pump relay connector in the fuse block. Refer to Using Fused Jumper Wires in Wiring Systems.
Does the AIR pump turn ON?
Go to Step 26
Go to Step 12
12
Remove the fused jumper wire.
Test the battery positive voltage circuit between the AIR pump fuse and AIR relay for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 41
Go to Step 13
13
Install the AIR pump relay.
Probe the AIR pump supply voltage circuit at the AIR pump harness connector with a test lamp that is connected to a good ground. Refer to Probing Electrical Connectors in Wiring Systems.
Command the AIR pump relay ON with a scan tool.
Does the test lamp illuminate?
Go to Step 14
Go to Step 34
14
Probe the ground terminal of the AIR pump connector with a test lamp that is connected to a battery voltage. Refer to Probing Electrical Connectors in Wiring Systems.
Go to Step 15
Go to Step 35
15
Connect a jumper wire between each of the terminals in the AIR pump harness connector and the corresponding terminal at the AIR pump. Refer to Using Connector Test Adapters in Wiring Systems.
Connect the fused jumper wire at the AIR relay connector in the fuse block, between the switched battery supply and AIR pump supply voltage circuit.
Measure the voltage from the AIR pump supply circuit at the AIR pump connector to the AIR pump supply circuit at the AIR pump relay. Refer to Measuring Voltage Drop in Wiring Systems.
Is the voltage more than the specified value?
0.5 V
Go to Step 34
Go to Step 16
16
Measure the voltage from the AIR pump ground circuit at the AIR pump connector and to a good ground. Refer to Measuring Voltage Drop in Wiring Systems.
0.5 V
Go to Step 35
Go to Step 25
17
Start and idle the engine.
Increase the engine speed to 1,500 RPM.
Monitor the HO2S bank 1 sensor 1 and bank 2 sensor 1 voltage parameters.
Command the AIR pump ON with a scan tool.
Do both of the HO2S voltage parameters decrease to the specified value within 10 seconds?
50 mV
Go to Diagnostic Aids
Go to Step 18
18
Disconnect the AIR shut-off valve outlet hose from the crossover pipe.
Is airflow present at the AIR shut-off valve outlet hose?
Go to Step 30
Go to Step 19
19
Connect the AIR shut-off valve outlet hose to the crossover pipe.
Disconnect the AIR pump outlet hose from the shut-off valve.
Is airflow present at the AIR pump outlet hose?
Go to Step 20
Go to Step 29
20
Connect the AIR pump outlet hose to the shut-off valve.
Remove the vacuum hose from the AIR shut-off valve.
Connect a vacuum gage to the hose.
Is the vacuum displayed on the gage above the specified value?
0 kPa (0 in Hg)
Go to Step 38
Go to Step 21
21
Command the AIR solenoid ON with a scan tool.
33 kPa (10 in Hg)
Go to Step 22
Go to Step 24
22
Connect a hand held vacuum pump to the shut-off valve.
Apply 33 kPa (10 inches Hg) of vacuum to the valve.
Does the shut-off valve hold vacuum for the specified amount of time?
1 minute
Go to Step 23
Go to Step 36
23
Inspect for a restriction or for a blockage in the AIR shut-off valve.
Go to Step 41
Go to Step 28
24
Disconnect the vacuum supply hose from the inlet of the AIR solenoid. Refer to Secondary Air Injection (AIR) Vacuum Control Solenoid Valve Replacement .
Install a vacuum gage to the hose.
Is the vacuum displayed on the gage above the specified amount?
33 kPa (10 in Hg)
Go to Step 27
Go to Step 31
25
Test for an intermittent and for a poor connection at the AIR pump. Refer to Testing for Intermittent and Poor Connections and Repairing Connector Terminals in Wiring Systems.
Go to Step 41
Go to Step 40
26
Test for an intermittent and for a poor connection at the AIR pump relay. Refer to Testing for Intermittent and Poor Connections and Repairing Connector Terminals in Wiring Systems.
Go to Step 41
Go to Step 37
27
Inspect the vacuum hose between the shut-off valve and AIR solenoid for a leak or restriction.
Go to Step 41
Go to Step 38
28
Repair the restriction or leak in the AIR shut-off valve outlet hose between the AIR shut-off valve and the crossover pipe.
Did you complete the repair?
Go to Step 41
29
Repair the restriction in one of the following components:
The AIR pump inlet hose
The AIR pump outlet hose
The AIR pump
Go to Step 41
30
Caution
Refer to Hot Exhaust System Caution in Cautions and Notices.
Repair the restriction in one of the following components.
The crossover pipe
Both exhaust check valves--Refer to Secondary Air Injection (AIR) Check Valve/Pipe Replacement - Bank 1 and Secondary Air Injection (AIR) Check Valve/Pipe Replacement - Bank 2 .
Both exhaust check valve outlet pipes
Go to Step 41
31
Repair the restriction or leak in one of the following components:
The vacuum hose from the intake manifold to the AIR solenoid
The vacuum check valve
The intake manifold vacuum port
Go to Step 41
32
Repair the short to voltage in the AIR pump supply voltage circuit. Refer to Wiring Repairs in Wiring Systems.
Replace the AIR pump fuse as necessary.
Go to Step 39
33
Repair the short to ground in the AIR pump supply voltage circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 41
34
Repair the open or high resistance in the AIR pump supply voltage circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 41
35
Repair the open or high resistance in the ground circuit of the AIR pump. Refer to Wiring Repairs in Wiring Systems.
Go to Step 41
36
Replace the AIR shut-off valve. Refer to Secondary Air Injection (AIR) Shut-Off Valve Replacement .
Did you complete the replacement?
Go to Step 41
37
Replace the AIR pump relay.
Go to Step 39
38
Replace the AIR Solenoid. Refer to Secondary Air Injection (AIR) Vacuum Control Solenoid Valve Replacement .
Go to Step 41
39
Ensure all components are installed and secured.
Ensure the AIR pump is connected.
Turn the ignition to the run position.
Does the AIR pump relay turn ON and OFF when commanded with a scan tool?
Go to Step 41
Go to Step 40
40
Replace the AIR pump. Refer to Secondary Air Injection (AIR) Pump Replacement .
Go to Step 41
41
Clear the DTCs with a scan tool.
Turn OFF the ignition for 30 seconds.
Start the engine.
Operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records.
Did the DTC fail this ignition?
Go to Step 2
Go to Step 42
42
Observe the Capture Info with a scan tool.
Are there any DTCs that have not been diagnosed?
System OK
DTC B0361, B0363, B0365, or B0367
Circuit Description
The following DTCs are for the left and right air temperature actuators:
B0361 and B0363 are for the left air temperature actuator
B0365 and B0367 are for the right air temperature actuator
The HVAC control module commands the air temperature actuators to move by controlling the voltage supplied on the control circuit. A signal voltage of 0 volts or a signal voltage of 5 volts rotates the air temperature actuator. A voltage of 2.5 volts stops the door. The HVAC control module determines the current position of the actuator by monitoring the voltage on the signal circuit. The feedback potentiometer is a function of the motor position. The HVAC control module controls the air temperature actuator door positions in order to maintain the selected air temperature.
The ignition is turned ON.
The HVAC control module detects the signal circuit is less than 5 counts (0.09 V), for B0361 and B0365, or more than 250 counts (4.9 V), for B0363 and B0367.
A default value will be used for the sensor data by the HVAC control module in an attempt to maintain the air temperature selected by the driver. This default value will be displayed on the scan tool.
Conditions for Clearing the DTC
The DTC will become history if the HVAC control module no longer detects a failure.
The history DTC will clear after 100 fault free ignition cycles.
The DTC can be cleared with a scan tool.
Diagnostic Aids
A disconnected or broken door may also set this DTC by allowing the air temperature actuator to travel to its internal stops, an overtravel condition. If condition not present, refer to Testing for Intermittent and Poor Connections in Wiring Systems.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
3. Tests for a default setting viewed by the scan tool.
4. Tests for the proper operation of the circuit in the high voltage range.
5. Tests for the proper operation of the circuit in the low voltage range. If the fuse in the jumper opens when you perform this test, the signal circuit is shorted to voltage.
6. Tests for a short to ground in the 5 volt reference circuit.
Step
Action
Values
Yes
No
Schematic Reference: HVAC Schematics
Connector End View Reference: HVAC Connector End Views
1
Did you perform the HVAC Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - HVAC Systems - Automatic
2
Install a scan tool.
With a scan tool, observe the appropriate Mix Mtr Position Feedback parameter in the Heating and Air Conditioning data list.
Does the scan tool indicate that the appropriate Mix Mtr Position Feedback parameter is within the specified range?
5-250 counts
Go to Step 3
Go to Step 4
3
Place the appropriate air temperature switch from the warmest position to the coldest position.
Does the scan tool indicate that the value of the appropriate Mix Mtr Position Feedback parameter remains near the specified value?
127 counts
Go to Step 4
4
Disconnect the appropriate air temperature actuator.
Measure the voltage from the signal circuit of the air temperature actuator to a good ground.
4.90 V
Go to Step 5
Go to Step 9
5
Connect a 3 amp fused jumper wire between the signal circuit of the air temperature actuator and the low reference circuit of the air temperature actuator.
Measure the voltage from the jumper wire to a good ground.
Is the voltage less than the specified value?
0.09 V
Go to Step 6
Go to Step 10
6
Disconnect the fused jumper wire.
Measure the voltage from the 5 volt reference circuit at the air temperature actuator connector to a good ground.
4.90 V
Go to Step 8
Go to Step 7
7
Test the 5 volt reference circuit of the air temperature actuator for a short to ground, or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 16
Go to Step 13
8
Test the 5 volt reference circuit of the air temperature actuator for a short to voltage, a high resistance, or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 16
Go to Step 12
9
Test the signal circuit of the air temperature actuator for a short to ground, or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 16
Go to Step 13
10
Test the signal circuit of the air temperature actuator for a short to voltage, a high resistance, or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 16
Go to Step 11
11
Test the low reference circuit of the air temperature actuator for a high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 16
Go to Step 13
12
Inspect for poor connections at the harness connector of the air temperature actuator. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 16
Go to Step 14
13
Inspect for poor connections at the harness connector of the HVAC control module. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 16
Go to Step 15
14
Important
Perform the recalibration procedure for the air temperature actuator.
Replace the appropriate air temperature actuator. Refer to Air Temperature Actuator Replacement - Left or Air Temperature Actuator Replacement - Right .
Go to Step 16
15
Important
Perform the recalibration procedure for the HVAC control module.
Replace the HVAC control module. Refer to HVAC Control Module Replacement .
Go to Step 16
16
Use the scan tool in order to clear the DTCs.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
The U codes are communication failures that have occurred on the data link. They may not mean anything other than there was voltage problem at some time in the past. Each module on the link sends out State of Health messages on a periodic basis. If another module doesn't see the message for some reason it will set a commo error code even though it may receive the next message a short time later. Most of the time the messages do not mean much but if there are a lot of them it indicates there is an electrical problem with the car.
Service Manual doesn't have a C2120 code.
Bill
Old Jun 30, 2008 | 05:12 PM
jski0236's Avatar
jski0236
Hi Bill,
Thank you for the reply as I am trying to determine the problem at this time.
Well, I took the car down for emissions with the vacuum leak and it failed as I thought it would. Now, the dealer is fixing the vacuum leak tomorrow under warranty as when changing the oil pressure sensor they caused the leak. My question is if the vacuum leak could cause the car to fail emissions and is it the cause of the DTC codes?
Sorry for all of the questions.
Jim
To DTC Code Meanings
