Cam Reccomendations W/ported Heads
Old Jun 24, 2008 | 04:31 PM
blackula 99's Avatar
blackula 99
Default Cam Reccomendations W/ported Heads
Need some input.. 99 frc /6speed 342 gears: Running lg street headers into borla cat backs,halltech stinger intake ,ls6 manifold. I plan on purchasing either the livernois stage 2 heads or the patriot heads. Question is,what is a good cam for this combo? I dont want a cam that has miserable idle quality but yet I want something that will make good power! I would like to see 425-450 rwhp..Any suggestions? Thank you in advance
Old Jun 24, 2008 | 07:17 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Have you checked out any of our X1 line of cams or maybe one of the Executive camshafts?
These were designed to have a very mild idle, and huge torque curve.
Let me know how I can help, I would be more than happy to speak with you on any one of our combinations.
Old Jun 25, 2008 | 12:40 AM
geterdone's Avatar
geterdone
Ms4
Old Jun 25, 2008 | 09:39 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
^^There are probably a number of cams out there that will work for you. I have seen some really good numbers made with an ECS blower cam, which is pretty mild, on a Z06. Had a great torque curve and made over 425 rwhp. ECS also makes a NA cam. It is a more aggressive than the blower cam. I have seen some good results posted from people who have used it. Not sure about its streetability.
Another possibility is the LG G5X2 cam. I know of one forum member who went with this cam and is over 430 rwhp with stock heads in his Z06 (Cobra4B).
Hope that helps.
Old Jun 25, 2008 | 10:42 AM
falcon5619's Avatar
falcon5619
Hope that helps.
Do you happen to know the cam profile of the LG G5X2 cam?
Old Jun 25, 2008 | 11:26 AM
nickolbag's Avatar
nickolbag
Definitly don't ned a big cam to get those numbers. I made 430rwhp w/ a 22x cam on ported ls1 heads and 4.10s.
Old Jun 25, 2008 | 11:39 AM
Independent1
St. Jude Donor '08
^^Here is a link with the info.
http://www.lgmotorsports.com/catalog...oducts_id=1509
Old Jun 25, 2008 | 11:45 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
http://www.eastcoastsupercharging.com/CustomCam.html
Old Jun 25, 2008 | 12:02 PM
Independent1
St. Jude Donor '08
^^I was just trying to provide objective (unbiased) information. I went with one of your ECS NA cams. Just have not installed yet because I have so much work to do on my car.
When it is all done around spring next year I'll post up the numbers.
To Cam Reccomendations W/ported Heads
