Clutch & Hydraulics ??
Old Jun 24, 2008 | 09:36 PM
LS1 REDBIRD's Avatar
LS1 REDBIRD
Default Clutch & Hydraulics ??
What are the symptoms of a clutch not fully disengaging or dragging due to a bad MC or slave.
Old Jun 25, 2008 | 09:43 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
Having had it happen to me, here are some of the symptoms I experienced. BTW, Bad slave cylinder.
Could not shift with engine running. Shifting worked fine with engine off.
When I started the car in first gear it would more even though I had the clutch pedal fully depressed.
You could drive the car around as long as you did not shift gears!
Old Jun 26, 2008 | 11:11 PM
LS1 REDBIRD
Anyone else have any experience with this issue?
To Clutch & Hydraulics ??
