ls6 intake gaskets
Old Jun 24, 2008 | 10:25 PM
blackula 99's Avatar
blackula 99
Default ls6 intake gaskets
Maybe a stupid question but Ill ask..... throttle body and intake gaskets should be switched out when installing ls6 manifold from another car ,whether they are in real good shape or not..correct? Thanx!
Old Jun 24, 2008 | 11:36 PM
LoneStarFRC's Avatar
LoneStarFRC
No. As long as they are in good condition, I have re-used them before with no problems.
Old Jun 25, 2008 | 03:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I just did a Heads/ Cam / Fast 90/90mm TB up-grade on my 02 ZO6. When I removed the LS6 intake I examined the intake gasket seals on the OEM 55,000 mile LS6 intake . If were to have reinstalled that manifold BACK ON the engine,,,I would have replaced the gaskets. They were very flat and didn't protrude above the intake flange very much.
On another note, I had to install and remove my FAST 90 intake approx 8 times (don't ask) and the NEW gaskets that I installed on that intake were in really good shape after each removal.
If the old gaskets are in good shape, look supple and protrude enough above the manifold to make a good seal on the head, there reusable.
I have reused other intake seals with good results on other C5 intakes.
Bill
Yes,,, they are expensive but work very well....
To ls6 intake gaskets
