Optimum Tire Pressure - Cold
Dec 25, 2001 | 01:52 AM
What's your take on the optimum tire pressure? Remember, cold.
[Modified by '98 Six Speed, 9:56 PM 12/24/2001]
Dec 25, 2001 | 02:37 AM
CI 5-6-7 & 9 Veteran
St. Jude Donor '05-'06-'07-'08
Re: Optimum Tire Pressure - Cold ('98 Six Speed)
Book says 30 PSI, so that's what I go with. :cheers:
Dec 25, 2001 | 03:22 AM
Re: Optimum Tire Pressure - Cold (vermjpv)
Same here!
Dec 25, 2001 | 08:51 AM
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Re: Optimum Tire Pressure - Cold (Dave68)
Me too..............Put 30 in and it will warm up to 32/33 Perfect operating temp for any Z rated tire :yesnod:
Dec 25, 2001 | 09:08 AM
I have been running 30psi all around. At 11,000 miles, the tires show very little wear. :chevy
Dec 25, 2001 | 11:07 AM
It's 30 all around for me.
:cheers: :cheers: :chevy :cheers: :cheers:
Dec 25, 2001 | 02:20 PM
Merry Christmas everyone,
Here''s my .02.
1 - I totally agree 30 lbs all around with the Goodyear RFT offers perfect tire wear. Once heated their lbs range is 33-34.
2 - I switched to the Firestone RTF and I am using the above as my guide for the rear tires.
3 - I like to drive with more front response so I am still experimenting. The rears I am keeping at 30 for rear reasons alone.
4 - To induce a little lighter steering under throttle I have the fronts at 33 (cold)
Personally I find the Firestone rears slide predictably. If wear was not a factor (and I may fool with this later) I would like to hear some feedback about lowering the rear pressure to 28 lbs for a better hookup.
Thank you,
Kenny
Dec 25, 2001 | 02:29 PM
The General says 30 ;)
Dec 25, 2001 | 03:26 PM
Re: Optimum Tire Pressure - Cold (MMarquez)
most of the tome it say's 30-32
Dec 26, 2001 | 11:10 AM
Re: Optimum Tire Pressure - Cold (Tom/99)
Actually, 13,000 miles for me, but same comments on 30 psi and little wear. :yesnod:
Ed
Dec 26, 2001 | 12:47 PM
For comfort, 30#'s is cool.......for maximum life, maximum pressure..........
For racing, 26/28 rears, and max at front............IMHO :rolleyes:
Dec 26, 2001 | 12:58 PM
Re: Optimum Tire Pressure - Cold (ZO6LS6)
30 in the rear, 31 in front - always want to keep the rear at 1-2 psi less than the front to keep control of the squirelly rear end.........
Dec 26, 2001 | 01:03 PM
I go with the manual also!
Dec 26, 2001 | 01:13 PM
31-32 up front and 30-31 in the rear.
Dec 26, 2001 | 05:58 PM
FWIW, running COLD rear pressure at 32 (checked and adjusted year round), I wore out the rear centers way early; I'm keeping the rear at 28-29 lately and they warm to 31-32.
