Help with tire wear
Old Jun 30, 2008 | 12:30 AM
jbauch357's Avatar
jbauch357
Default Help with tire wear
So I've been fighting tire wear issues on my '02Z since I brought it home. I am scrubbing the very inside and very outside edges off, while leaving a good deal of rubber left in the center portion of the tire.
It's really bad up front, on the rear it's not as bad - but I want it to be perfect. I've tried different pressures, alignment settings - all sorts of stuff and I can't seem to find the magic recipe.
Before I was running the tires hot at about 32 front and 30 rear, as that's where the car grips the best and had the best balance - so I'm wondering if I was just rolling over onto the edges too mutch? Right now I am running the following alignment and pressures trying to get more wear on the center of the tires.
Front
Camber -1.3
Toe +0.05
Caster 7.4
Pressure (hot) 36
Rear
Camber -1.1
Toe 0.00
Pressure (hot) 32
FWIW I drive the **** out of the car on the street and it sees track/auto-x duty so I am hesitant to remove any more camber than I already have - as there is a substantial difference in grip compared to the over -2.0 degrees front camber and -1.5 rear that I used to run...
Anybody else having similar issues? I am pretty sure that I was just running too low of pressure, but figured I would throw a line out there and see what people think...
Old Jun 30, 2008 | 01:59 AM
RIJVETTES's Avatar
RIJVETTES
A lot of guys religiously put no more than the GM recommended 30 lbs cold. But I have always run 35-36 lbs cold in my C3, C4 and C5- with good alignment. I've had NO tire wear problems -inside, outside or middle, and a consistant 60,000 miles on the tires- Goodyear or BFG's. I've been fortunate to mostly drive on dry, good condition roads and freeways in San Diego area. You'll also get slightly better gas milage due to less rolling resistence, and a firmer ride- but remember, it is a sports car.
Old Jun 30, 2008 | 09:28 AM
Dave68's Avatar
Dave68
You can accelerate/reduce wear to inside edges and center if the alignment is correct, but once the alignment is out, it is very difficult to correct/overcompensate the wear pattern (that occured during the out-of-alignment condition) after the alignment is corrected.
I find that 28-32 psi (cold) is good for my rear tires and 30-33 is the right pressure for the fronts.
Old Jun 30, 2008 | 11:07 AM
VetteDrmr's Avatar
VetteDrmr
Josh,
I think what you're seeing is a combination of your driving style (do you autocross on the same tires?) and your alignment.
That much negative camber will definitely wear the inside of the tread, and cornering at the limit will get the outer edges.
HTH, and have a good one,
Mike
Old Jun 30, 2008 | 11:38 AM
jbauch357's Avatar
jbauch357
Originally Posted by VetteDrmr
Josh,
Mike
I was reallly hoping this wasn't even possible - that I have an aggressive alignment and drive hard so I am just scrubbing the inside and outside edges off... I am wondering if I need to try a tire other than the Michelin PS2 that will roll less or if I still need to bump up pressure even more to keep the tire flatter...
Old Jun 30, 2008 | 11:04 PM
VetteDrmr's Avatar
VetteDrmr
Actually, I'm thinking that might hurt your situation. Adding pressure will stiffen up the tire, localizing the load on the shoulders even more. Your pressures are higher than I run already (also more agressive camber). If you drop the pressures down a couple of psi that *might* help.
My fronts wear the inner and outer edges in a manner similar to yours (maybe not the same degree, but the same pattern). I think the staggered tire sizes also aggravate the problem, since the car naturally understeers so much with the 245/275 split.
Mike
Old Jun 30, 2008 | 11:26 PM
mjorgensen's Avatar
mjorgensen
Actually I have seen that the PS2 tire NEEDS more air to keep it flat and not wear the edges. I have worked with the Viper groups that have seen this issue and the higher pressures like 32-34 cold help considerably to get the center of a wide tire to work since the side wall is a lot "softer" than you might think.
Old Jun 30, 2008 | 11:59 PM
thetaxman's Avatar
thetaxman
use less caster around 4 degrees
assuming all else is OK
Old Jul 1, 2008 | 01:36 AM
jclarksnakes's Avatar
jclarksnakes
Josh,
...If you catch a wear pattern early you can often correct it with tire pressure. After the wear has gone too far it is tought to get tire pressures to make the rest of the tread wear and catch up to the worn spots. Bad news as PS2s are expensive. But you already knew that.
Jeff
Old Jul 1, 2008 | 10:23 AM
jbauch357's Avatar
jbauch357
yeah, I've always run lower pressure than I am now because that's where the car has the best stick and balance (and was hoping that lower pressure would let the tire compress under load a bit more and bring more wear to the center, but I think all it was doing was allowing the side wall to roll over). doing that means I've gone through two sets of PS2's with both inside and outside edges being scrubbed way faster than the centers. initially I tried fixing this by reducing the aggressiveness of my alignment but now that I am increasing the wear on the outer edges I know that isn't the correct resolution to the issue and am trying higher pressures. thanks for the ideas though, the tire wear on this car has been harder to dial in than any other car I've owned before...
I sure hope this holds true on my car, I am getting damn tired of replacing full sets of PS2's on a yearly basis at 15-17k miles...
I'm curious why this would have an affect? I didn't think caster would have a major impact on tire wear?
Originally Posted by jclarksnakes
Josh,
Jeff
Exactly, I have been watching my tires closely with this set - and am trying to resolve the problem before it's too late like it was with the previous set
Old Jul 1, 2008 | 09:38 PM
thetaxman's Avatar
thetaxman
normally it would not
but
have someone turn the tire and look from outside and you'll see why
7 degrees of caster is ALOT
To Help with tire wear
