I think you will find that the BMW bushings and GM bushings are made by the same German company.
These are the 10mm bushings that came out of my car and were replaced with the BMW busings. As you can clearly see they are "Made in Germany".
Exactly! Here is what I think happened: GM "Borrowed" this design from BMW. It is a part that has already been in production for BMW, so it was probably cheaper for GM to just buy from the same place that BMW gets their couplers made. I have rebuilt several torque tubes and both the GM and BMW parts are identical. I don't believe that one is any stronger than the other.
I have also seen these "made in Germany" couplers in the Pontiac GTO as well as the Cadillac CTS.
Hello, this info is a bit dated as I posted it back in 2005....
Starting in model year 2001 production Z06's were fitted with P/N 12564457 {Improved Torque Tube & Drive Shaft Assembly-Torque Tube Assembly } and these P/N's were slowly introduced into all model corvettes that year. My contact at GM could not give me specifics but as of today all Manual Trans replacement Torque Tube Assembly's have P/N 12564457.
Tq Tube P/N 12564457.
The driveshaft is upgraded from a metalmatrix composite to aluminum alloy 6061, and it is increased in diameter from 55mm to 63mm. Driveshaft couplings have also been upgraded from 10mm to 12mm on manual-equipped models for additional strength and durability
you can run two solid couplers and its very smart... i am doing it now and i spoke with another forum member that has been running like that for a while.
Originally Posted by GrantB
1) The older 10mm bushings are no longer available from GM, correct? The guy at the parts counter only shows one part number for all C5s, regardless of year.
2) Can the newer 12mm bushings fit in the older-style torque tubes if you use different fasteners? My '99 bushings are 1.10" long, and I can get a bolt with a 12mm shoulder that will neck down to thread into my tube.
3) Are the 12mm bushings stronger than the older 10mm ones?
4) I'm assuming running two (or possibly even one) solid bushing is not the smartest thing to do? I was considering trying it with two solids and measuring runout to see how bad the binding might be.
