My mechanic tried this without success. We had the pics and directions from the forum. What did he do wrong? It didn't work. I was not there so I'm assuming he followed the guidelines.
The car was put on his lift and he says that he took the tension off of the spring to back out the bolts. One at a time and then dropped the car back down and checked the distance between the tire and the fender. No difference! ??? I guess I'm wondering if he really did lift the spring to take the pressure off the bolt. With the car in the air I'm kind of wondering what he would of used to do this. This guy is the best mechanic in town and has done other stuff to my car with no problems. Thanks for your input.
You must drive the car a while after lowering to let the suspension settle. It will usually look like it's actually higher right after you jack the car up as the suspension is loaded and must settle back down.
Drive it for a while.
Originally Posted by lionelhutz
Try driving the car after you adjust the bolts.
Peter
Originally Posted by briann510
Get your wheel off the ground and look under there and see if the bolt is indeed turned all the way up with no space between the bottom of the bolt bushing flat surface and the lower A arm facing. You will be able to see right away if the bolt has been turned all the way or not.
Thanks for the input. Just talked to my mechanic and he said he did leave the bolts all the way out but in doing so he "DID NOT" take the tension off the spring. I drove the car several miles and it didn't lower a bit !!! He can't see how the spring tension would make a difference. Any ideas??? Thanks.
When you get your lowering issue resolved, don't forget to have your wheels aligned. I suggest you drive your car a 100 miles, or more, to allow the suspension to settle. Good luck.
You can either look and see how much bolt is above the front spring or reach under and feel. My car is lowered to the max on the stock front bolts and I have about 1.3 inches of bolt above the spring. Is it possible he went the wrong way with the bolts? I believe the front are reverse thread. Someone correct me if I am wrong.
They are not left-hand thread. They are simply screwed in from the bottom of the spring. This makes it seem like you are loosening the bolt when turning it from the top.
I lowered mine last night to the max w/ stock bolts & bushings. Took measurments before & after. Not even a 1/8" difference. I'm not a bit worried because I have read in previous post that you have to drive on it for a couple of hundred miles to let things settle and then get a propper allignment. On the rear I took out the stock bolts and put in the longer lowering bolts and WOW! It's really dropped to the point that I may have to bring it up a tad. I have'nt moved the car , and its still on the ramps, but if the car settles any lower in the rear when driving around then I will definely have to raise it up a little. I left 4 thraeds @ the top of the longer lowering bolts. Has anyone tried the longer lowering bolts in the front? If so what is your oppion?
Ahhhh...I don't think longer bolts in the front wouldn't give the same results as in the back...unless you want to raise the front end up even more than oem.
Some have used the C6/Z06 front bolts or HARDBARUSA front bolts, which have different thickness of bushings. Some elect to cut or remove the bushings, or remove the bolts in the front entirely. But then you have the spring rubbing to contend with. Those same people usually fashion some type of pad for the spring to rest on.
My personal oppion (sic)...going to low (ala "lowrider") really screws up the engineering that GM engineers spent lots of time/money to figure out. However, lowering on stock bolts/bushings might allow for an improved ride (road condition?) and is within the 5/8-3/4" lower recommendation which GM suggested.
It's your car to do with as you please.
I did the front this afternoon. I backed it off what seems like 30-40 turns (OK, quarter turns with the available room.) Is there a point where you feel it bottom out? I am still not sure if I turned it enough.
I drove it for a bit and I don't see a difference...is there a time/distance factor before I should try turning it some more?
