How hot is too hot?
+1 and also check your thermostat it may be going out. Those where my temps before mine took a crap.
If your thermostat is going down does that mean that your car is really overheating or does it just think that its overheating?
1) The "scrape guard" is an air dam ......
2) the thermostat is NOT what reports engine temperature .... that is the "Engine Coolant Temperature" (ECT) sensor.
3) The thermostat is a mechanical device that determines when coolant should circulate to the radiator. When the thermostat is closed coolant flows only inside the engine ... when it is open coolant circulates through the engine and then through the radiator
4) 180 degree thermostats are a waste of money .... if you need a new thermostat install a stock thermostat.
Keep driving that thing until you get temp warnings, then pull over (if stuck in traffic) or give it some easy cool down driving (if on track).
PS... I have learned a few things on this forum...
I'll learn how to fix cars when I retire!
Look at the front of the engine ..... you will see several hoses in that area of the engine. There are two large diameter hoses ... one is clearly visible as it goes from the top of the water pump assembly to the right top side of the radiator (the radiator is that finned item just in front of the two cooling fans forward of the engine). The other hose is on the other (left) side and connects the bottom lower corner of the radiator to the lower side of the engine.
Coolant circulates from the bottom of the engine to the top of the engine. When the thermostat is closed (cold engine) the coolant circulates from bottom to top and back to the bottom via the water pump.
Once the coolant is hot enough (usually about 185-190 degrees with a stock thermostat) the thermostat opens aand coolant flows from the top of the engine, via that large upper hose, into the radiator. It then circulates "down" through the radiator, and now cooled enters the bottom of the engine to flow back to the top.
To test for proper coolant flow ....
Start the engine COLD. Set your A/C to OFF .... then watch the temperature gauge, and as you see the temperature approach 200 degrees go and CAREFULLY feel that upper hose. You are feeling to see if it is getting hot (or is hot). After a couple more minutes that upper hose should DEFINATELY be hot. If it is not, it indicates that coolant is not circulating properly. The culprits would be either a stuck thermostat, or a failing water pump impeller.
CAUTION - the two cooling fans can start at any time once the engine is up to temperature. Keep fingers, clothing, etc. clear of the fans at all times.
Class dismissed ....
I don't want to mess anything up but all this time my car has been running a little hot but I never really thought that everyone meant "IN" the fins of the pieces...I was more thinking grocery bag blockage is what it took to make a difference...
So without compressed air...should I use a garden hose or will it take higher pressure to blast the stuff out?
Thanks,
Donnie
