t-stat
Old Jul 4, 2008 | 03:07 PM
MaxLean's Avatar
MaxLean
Default t-stat
I'm sure this has been addressed before, but what 160 degree t-stat do I need for a '99? Do I have to get the $45 t-stat/housing assy, or can I just get the $20 t-stat by itself and still use my existing housing? I've been under the impression that there was a running change made at some point in the production of the LS1 and that the earlier ones needed the housing/t-stat assy. Can anyone clear this up?
Scott
Old Jul 4, 2008 | 03:25 PM
Russ K's Avatar
Russ K
The late 2003 & newer style water pumps use a separate thermostat. Your car needs the housing & stat.
Russ Kemp
Old Jul 4, 2008 | 03:59 PM
MagRedConv's Avatar
MagRedConv
Here's the clue. Go check the stat housing on your car. If you have the circled ear below you need the housing & stat, if not, only the stat.
I have a '98 and had the pump replaced; turns out they put an '04 on it so I learned the hard way.
Old Jul 4, 2008 | 08:04 PM
vettenuts's Avatar
vettenuts
The correct answer is neither, shim the one you have for less than $1.00.
Link to thermostat mod
To t-stat
