Don't Tow It - Column Lock
So, you get in your car, put the key in the ignition, turn the key to start the car and get the DIC message that the column is still locked. You try and turn the steering wheel but sure enough it is still locked.
What has worked for me is:
Turn the car off
Remove the key
Column is still locked
Put hands on the steering wheel at 10 and 2 o'clock
Try to turn left and right quickly and semi forcefully 3 or 4 times
The steering wheel won't move much when you do the step above
Put key back in the ignition put don't turn the key at all
Put your left hand on the steering wheel at 2 or 3 o'clock, palm facing you, you are grasping the inside of the steering wheel
While pulling down with quite a bit of force on the steering wheel with your left hand, like you are trying to turn to the right, very slowly turn the ignition key as if to start the car.
The steering column should unlock before you have turned the key far enough to start the car.
If it doesn't work the first time try again as this technique works quite often, maybe apply more downward turning to the right force on the steering wheel. You won't hurt anything.
If it does work, if probably won't lock up again if you leave the key in the ignition. Call Corvettes of Houston and have them overnight a Column Lock Bypass to you. Take 15 minutes and install the bypass.
This technique is mentioned in other posts but I thought bringing it out to its own post might save people some serious grief.
Go D'Backs
David in AZ
(and I got the car home).
Now I need to install the "Doctor Don's" Column Lock Simulator Kit I just bought...
Anyone have experience with this particular kit?
THANK YOU David and Corvette Forum!
(FYI: I'm an original owner of the 2002 Z06)
http://forums.corvetteforum.com/foru...s-or-more.html
