Drain plug location?
Old Jul 5, 2008 | 12:01 PM
pat03z06's Avatar
pat03z06
Default Drain plug location?
Anyone know where the radiator drain plug is located?
Old Jul 5, 2008 | 12:33 PM
Oldvetter's Avatar
Oldvetter
It is under radiator on passenger side. If it is stock, it takes a 1/4 inch drive (square) to open. You will have to jack up to see.
CAUTION: Only turn it 90 degrees and then pull it out. IF you turn more than that, you shear off pin(s). NAPA has replacement for under $5, and it can be opened by hand.
IF draining, return car to level to drain.
Old Jul 5, 2008 | 01:07 PM
ZeeOSix's Avatar
ZeeOSix
Great info!
Old Jul 5, 2008 | 05:28 PM
pat03z06's Avatar
pat03z06
Thanks!!! I'm done with the work.
To Drain plug location?
