should i add a 160 stat
Old Jul 5, 2008 | 04:38 PM
nicks01's Avatar
nicks01
Default should i add a 160 stat
I installed the diablo proformace tune & i love it should i add 160 stat on my 91 i put a hyper chip in & it was requierd what do you think
Old Jul 5, 2008 | 04:43 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
To get the full benefit of a lower thermo, you'll need to change the fan settings to a lower temp also. If not, a 160 thermo will just open at 160 and temps will be close to normal. But if you combine the thermo and the fans, you get lower operating temps all around.
Old Jul 5, 2008 | 04:49 PM
Oldvetter's Avatar
Oldvetter
If you drive in the winter (in New York), I would not do a 160 Stat (and re-program fans). Your oil will not get hot enough to burn off water contaimination in the winter.
Old Jul 5, 2008 | 04:58 PM
nicks01's Avatar
nicks01
I don't drive in the winter should i change to the 160 do you if the pre set program on the diablo lowers the fan sittings
Old Jul 5, 2008 | 05:53 PM
vettenuts's Avatar
vettenuts
Why not just modify the thermostat you have? You can shift the temp down in increments until it runs where you want it to.
Old Jul 5, 2008 | 05:59 PM
C5Pat's Avatar
C5Pat
I have the same programer, you have to set the fans with the programer. Very easy I think I set mine at 197,ON
Old Jul 5, 2008 | 06:39 PM
usnavyfc's Avatar
usnavyfc
St. Jude Donor '09-'10
If you keep the 160 thermostat in and just not reprogram the fans during the winter will be ok? and then just reprogram them in the spring.
Old Jul 5, 2008 | 07:05 PM
FourG63 97GST's Avatar
FourG63 97GST
how do you do this?
Old Jul 5, 2008 | 08:20 PM
nicks01's Avatar
nicks01
you got me how do you do this
Old Jul 5, 2008 | 08:23 PM
nicks01's Avatar
nicks01
I used the pre set program can i keep it & still set the fans lower
Old Jul 5, 2008 | 08:28 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by FourG63 97GST
how do you do this?
You add a shim between the pellot actuator rod and the thermostat body.
A .100" thick shim will lower the cruising speed temperature 10-15 degrees.
Old Jul 5, 2008 | 09:29 PM
geterdone's Avatar
geterdone
sounds good
Old Jul 5, 2008 | 09:56 PM
vettenuts's Avatar
vettenuts
how do you do this?
Thermostat mod
Old Jul 6, 2008 | 09:17 AM
nicks01's Avatar
nicks01
what did you set the fans to shut off
Old Jul 6, 2008 | 09:19 AM
nicks01's Avatar
nicks01
Old Jul 6, 2008 | 02:53 PM
Quicksilver Vert 01
Fan 1 off at 185 degrees F. seems to work well with the modified factory thermostat.
Old Jul 6, 2008 | 03:10 PM
thetaxman's Avatar
thetaxman
use a real radiator and run a 192 t-stat
To should i add a 160 stat
Old Jul 6, 2008 | 10:59 PM
RogerT's Avatar
RogerT
Default Thermostat change
I put a 160 degree thermostat in. Baseline temperature dropped from 198 degrees to 178 degrees. I have not changed the fan settings.
Roger T
Old Jul 6, 2008 | 11:58 PM
falcon5619's Avatar
falcon5619
Roger T
Is the AC on when you notice the 178? When the AC is on the fans will be on so you will notice the drop in coolant temp depending on the ambient temp. The point is, you need fans or air flowing over the radiator in order to get the coolant temps any lower. I live in Florida and with a stock thermostat is still takes about 20 minutes of driving to get my oil temp up to 195-205. I don't really see the benefit of swapping the thermostat, just program your fans to come on a little sooner so you don't go up into the 220s in stop and go traffic.
Old Jul 7, 2008 | 08:00 AM
Quicksilver Vert 01
Originally Posted by 8VETTE7
Putting the colder T'stat in without resetting the fan settings will do NOTHING for the first choice above. Engine temp will climb until the fan kick on speed and then drop to the fan kick off speed and repeat the cycle.
Absolutely correct! Only the cruising speed temperatures will be lower.
