Oil Cooler Problems - worried
Oil pressure cold is 55 lbs. Warmed to about 175 degrees, the pressure is still 45. These are at idle.
Driving environment in Phoenix AZ today - 110 degrees ambient, driving with A/C on. Coolant at 200 degrees at 65 MPH and oil temps at 219 degrees. In stop-and-go city traffic for only 5 miles, coolant went to 232 degrees and oil rose to 225 degrees.
Note, with the stock 1999 radiator, freeway driving with the A/C on yielded 196 for coolant and 220 for oil with no cooler.
Problem - why am I not seeing improvements?
BIGGER Problem - once fully open for flow through the oil cooler, oil pressure drops to about 20 at idle and does not go above 30 under throttle. It dropped to 16 psi at idle while city driving.
Can anyone shed some light? The only thing I can think of is that they used lines to the oil cooler that have too large an inside diameter, so pressure is dropping.
Note - oil cooler bypass is mounted by the filter, radiator is clean and no debris anywhere. Fans are working properly.
Thanks in advance for your help. Paul
Bill
8VETTE7 - I will post the findings and I hope there is some simple fix. Or, the oil cooler is being completely bypassed tomorrow afternoon until a solution is identified.
did you change your water T stat to 160 and lower the fan switch temps??
fans make huge difference !
