What LT Headers do not give 02 sensor problems?
Old Jul 8, 2008 | 04:49 PM
EdsC6Z06's Avatar
EdsC6Z06
St. Jude Donor '05-'06-'08-'10
I think it's safe to say....if you change to LT headers, expect codes. Plan on tuning the o2's out. You want to play......
Old Jul 8, 2008 | 04:53 PM
CanadianVetster's Avatar
CanadianVetster
Default LT Streets
My LG streets were installed, and to my understanding the shop had to change the O2 senors from the front to the back and only plugged in the rears, (now fronts) so only 2 senors connected. They did get all four to connect, but apparently that is not the "right way" to do it.
No codes and runs very well....
Old Jul 8, 2008 | 10:12 PM
Millenium Z06's Avatar
Millenium Z06
Moderator
Originally Posted by BlackZ06
Sorry .... but you misunderstand the issue.
The catalytic converters (cats) are VERY sensitive to temperature ..... they want HOT gases from the engine to assist in the catalytic process. On a cold engine start the cats are too cold to catalyze the gases and take a while to come up to temperature before they start working (light off). Many Corvettes are fitted with "pup" cats that are directly below the stock manifold .... they heat fast and once they are working they reduce pollutants and help heat the main cats to get them to "light off".
Long Tubes are called that because distance the hot exhaust gases have to flow has been "lengthened" over the distance the stock manifold flows the gases. That added distance is enough to affect the performance of the cats, especially in cold start situations. The cats can take longer than the PCM is programmed to allow for "light off", which will set codes. The cats can be working, but not efficiently, which can set codes. The cats need to be VERY hot to work correctly .... usually above 800 degrees.
That's why there are ZERO LTs certified by the CARB as smog legal, and never will be .... the LTs do the opposite of what the cats are designed for and need ... to be as close as possible to the exhaust ports in the heads.
And that's why anyone with LTs is gonna get rear O2 sensor codes at various times with a "stock" PCM ..... and why many people with LTs have the rears "tuned out" of the PCM DTC checks.
No I think you misunderstand the question/ issue, the rear O2's are the ones causing the codes, LG and Random Tech both told me it was an efficiency issue with the cats in that they flow too well. Now rather that causes them not to retain the proper heat or not is debatable, they didn't say so I cant argue that. But that dosent make my comment anymore wrong than your comment. Also I believe that 2002 and up do not have pup cats so that would void the many corvettes thought. The fact that my car dosent smell like a gas station tells me that my cats are indeed working.
Old Jul 8, 2008 | 10:23 PM
Millenium Z06
Moderator
Originally Posted by XtremeVette
Ok let me clear a few things up as we are on different pages.
1. You said you have only found 1 post about codes? You need to search again! I'll gladly give you links to over 50 posts on 02 sensors and codes related to the front sensor banks as the rear banks everybody running headers knows you turn off.
2. You mention 4 02s. and with a stock system yes you have all 4. However when running headers, most manufactures only tell you to run 2. The rear o2's in the front positions. The rear 02 banks are completely turned off so its impossible to get any codes at all from those.
4. Iam not talking of the same codes as you mentioned. The codes Iam referring to are on the front sensor banks and are switching issues due to 02 sensors either heating up too quickly or not quickly enough. This is because of the new location of the 02's in the pipe. Hope this clears things up.
Please anybody having a switching code being thrown (P0153) for example. Chime in.
1. I said codes for the FRONT O2's not the rear; so lets see a list of threads that had front O2 issues after headers that are directly related to the headers and not a crossed O2 or an O2 that went bad.
2. I, as many here do, wanted to be as close to smog legal as possible and LG had just started offering there 4 O2 LG Pro systems so I got that one.
3. Why wouldn't you just use the front O2's in the front as the rears are different are they not? LG's come with the front and rear extension harness.
4. I have no idea what you are talking about there, but that may be because I used my fronts on the front. I have had my headers on for 4 years with not a single front O2 code. The only codes I get are from the rear's as I haven't been tuned yet (holding out till I get a cam)
Old Jul 8, 2008 | 10:32 PM
Millenium Z06
Moderator
Millenium Z06 just curious as to what headers your running and did you get extensions to run all 4 o2's? On a side note, you mentioned the codes you were referring to had to do with the rear sensors and that those usually get tuned out. Are you referring to "not to report" or "tuned/turned off"? Cause Iam thinking if you were running all 4 sensors then had codes being thrown off by the rears causing you to turn them off, then you would be running only the front sensors once again and the rears would not be doing anything? Just trying to understand, Iam at desperation right now just trying to get rid of my codes.
LG Pro's and yes, I have the extensions but the rears still weren't long enough so I made my own harness. My car hasn't been tuned so I am still running with 4 O2's. I have not decided what I am going to do with the rears yet because I live in Collin Co in Texas and they test the computer, you can only have 2 "Not Ready's". When I get my inspection report my rear cats/O2's show Ready. My understanding is that turning them off will cause them to show "Not Ready".
What codes are you getting? Why don't you just get extensions and put the front back in? I'm fairly certain they are different and would that not be the cause of your codes?
Like I said earlier, I get absolutely NO codes from anything on my car except the rear O2's and I only get them about every 300-500 miles.
Old Jul 8, 2008 | 10:36 PM
BlackZ06's Avatar
BlackZ06
Huh ?????? I'm talking about the rear O2 sensors ..... what are you thinking ???? The whle point to this issue is the rear sensors see that the cats are not working as efficiently as they should.
The cats are "too efficient" ??????????? you are clueless ........
let's see the 2002 and 3 and 4 cars had no pup cats .... that's 3 years ..... the 1997, 1998, 1999, 2000 and 2001 cars (there are exceptions to this) had pup cats .....5 years versus 3 years .... I'll stand by my statement that "MANY" Corvettes have pup cats ..... in fact I'll make that the MAJORITY of C5 Corvettes have pup cats ......
Old Jul 8, 2008 | 10:48 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default I really would love to know a tuners point of view
As far as all the posts I have read about this issue. From what I have read, by having the codes not report won't set off any "not readys". I believe that happens when you have a code that you fix but that you don't give the car enough time to fully clear the code. GM states that it is about 40 warm up cycles before a code goes completely away. If you don't complete this cycle the code will show up stored and the result will be a "not ready". Please if any tuner finds this to be incorrect...please by all means correct me as Iam not a tuner.
Old Jul 8, 2008 | 10:52 PM
XtremeVette
um ok, I just noticed what you said. So you too are getting codes. hmmmm interesting. So you would also be forced to turn your rear 02's off. When you got your report, did you have any strikes against you because of the codes or where they completely gone because you drove the car long enough to wipe the codes out of the PCM's memory and thus the inspection didn't pick up on it?
Old Jul 8, 2008 | 11:13 PM
Millenium Z06
Moderator
It didn't show any codes, I get the 0420 and 0430 but clear them thru the DIC and continue on. It also showed the rears as ready so I guess it may be that the car was driven enough to not list the codes. Now about 2 years ago, when my ebcm went out, GM replaced that computer and reset the other. When I went for an inspection about a month later, I got 3 not readys and one was the rear O2's. It took about 500 miles before they were ready and the GM drive test thing didn't fix it. My concern is that they (the State) will tighten the smog laws and that a not ready will cause you to not pass; so if I get a tune and have them tuned out and the law changes, I screwed.
Old Jul 8, 2008 | 11:16 PM
Millenium Z06
Moderator
So.. I'm going to take your word for it as fact instead of LG, 21stCMC and Random Tech huh? yeah.....
Old Jul 8, 2008 | 11:17 PM
XtremeVette
I hear ya man, thats my biggest fear. I don't want to go through any crap with a "not ready" cause of 02's and thus fail.
Right now Iam getting the P0153 and P1153 codes and like you I just delete them with my DIC. You said that your rears are showing "ready". How do you check for that? or was that at the inspection place and that is what it showed.
Old Jul 8, 2008 | 11:32 PM
Mike Mercury's Avatar
Mike Mercury
this has become an interesting discussion; as I too will be looking into headers as a winter mod later this year.
But lets not get sidetracked by bad facts.
there were no pupcats on 1997 and 1998 C5's
1999 and 2000 saw a small number of C5's with pupcats; based on where they were to be shipped (mainly Kalifornia and the Pacific Northwest).
In 2001, all C5's were built with pupcats; and that includes the 01 Z06.
Starting 2002; pupcats continued being factory installed on alll C5's... except for the Z06. And this continued through the 2004 model year.
Old Jul 8, 2008 | 11:36 PM
  #33
clayton1's Avatar
clayton1
Banned Scam/Spammer
Ive got headers,hi flow cats (dynatech) for almost 2 years, with all 4
O2 sensors. I get the P0430 code. I delete it , it comes back pretty quick (quick=usually about 20mins).
I dont remember seeing any pup cats on my 99 when I installed headers.
Old Jul 8, 2008 | 11:43 PM
  #34
XtremeVette
ok but how do you get pass emissions with codes? I think in BC you only need emissions what every 10 years?
Old Jul 8, 2008 | 11:46 PM
  #35
Mike Mercury
I know exactly what you mean.
When I went with aftermarket valve covers (also relocating the coils) I had many ask why I went through all the trouble of duplicating the plumbing of the crankcase ventillation system.
I simply said that I had been driving that Corvette for five years... completely error free; and I wanted it to continue that way.
And I don't even have a catch-can - and don't need one either.
So; I'm like you in that I don't want to mess with any codes or intermittant problems. I guess it's my age. In my earlier years the first thing I ripped off was that funky air pump, removed the cats, and pry'd out that filler neck restrictor that was forcing me to use unleaded gasoline.
Old Jul 9, 2008 | 12:24 AM
  #36
clayton1's Avatar
clayton1
Banned Scam/Spammer
Pretty sure the only city in BC you need to pass "Air Care" or emissions..etc is in Vancouver, actually, there may be other places but Van is the only one I know of. So Im good.
Old Jul 9, 2008 | 04:59 AM
  #37
Millenium Z06
Moderator
The inspection place showed that on their diagnostic which is done as part of the saftey inspection. I assume some of the tuner software can see this also but I dont know. I am curious as to why you would get those codes though instead of the ones most get.
To What LT Headers do not give 02 sensor problems?
Old Jul 9, 2008 | 08:48 AM
  #38
XtremeVette
Actually this apparently is a very common problem with long tubes, I just got a PM reply from Chris@EastCoastSupercharging and he agrees.
His quote: "Thats one of the biggest issues with the long primaries.The sensors dont get as warm and tend to have problems switching. You could try using a new sensor and they should be good long enough to get you to pass..."
Old Jul 9, 2008 | 11:02 AM
  #39
vsocks1's Avatar
vsocks1
Well maybe that is another advantage with American Racing and thier shorter primaries?
Old Jul 9, 2008 | 11:20 AM
  #40
XtremeVette
must be....but one big thing bothers the hell out of me.
The sensors on the C5's are heated. They have 4 wires. They cost considerable amounts of money. They because they are heated are suppose to reach full operating temperature within 30-60 seconds of startup! Thats way not enough time for your car to hit its operating temperature. So why is this heat thing even an issue? I really don't understand it at all! If the sensors are heated by themselves to work so quickly what difference does an exhaust header vs stock manifold have?
