What LT Headers do not give 02 sensor problems?
Old Jul 9, 2008 | 07:07 PM
  #61
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Originally Posted by mrm1149
I took a trip 3 years ago to the Vette Doctors......ARH w/high flows and a tune Not one issue You oughta think about running over there tsts
ARH
Old Jul 9, 2008 | 08:00 PM
  #62
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Originally Posted by Millenium Z06
Did you put your headers on? if so what did you do with your O2 while they were out? I replaced my rears with Bosch units and remember reading in the instruction paper that they, O2's, will become contaminated and not work properly if left exposed to the atmosphere too long. Don't know how much truth there is in that warning but it's a thought.
woah!!!!!!!!!!! hold on....thanks for this information. My 02's were "exposed" in my garage for over a month and a half! hmmmm might have a winner here. This is definitely news that I never heard before.....Again, thanks for the information!
My 02's were not only "exposed" they had over 72,000 miles on them. I thought that they could be used again but understanding this new information....prolly was not a good idea.
Old Jul 9, 2008 | 08:51 PM
  #63
BlackZ06's Avatar
BlackZ06
Your O2 sensor's ceramic element is exposed to air 5 minutes (at the most) after you turn off your engine ....... people store cars and start them a year later and the sensors work fine.
Now, the fact your sensors have 72,000 miles on them MAY be contributing to your problem. They get less efficient over time and mileage (which is why the PCM does the lean/rich switching - to test them) ..... so if you want to spend the money, a new set of sensors can't hurt (well, other than your wallet).
Old Jul 9, 2008 | 09:17 PM
  #64
XtremeVette
hmmmm crap! thought I was getting let onto something here.
I really don't like spending extra cash, but at the same time. I want the problem gone and my tuner is 150 miles away, so I would rather have fresh sensors when he turns some codes to "not report"
Old Jul 9, 2008 | 10:51 PM
  #65
BlackZ06's Avatar
BlackZ06
Try this .... sit down .... put aside all the arguements that have raged in this thread ...... and think about what is IMPORTANT to you.
If ..... say .... 20+ HP is more important than being "legal" ... then screw the codes .... go for all the mods you want ..... but understand that has a "cost" when the car has to be tested.
If not having to worry about passing the test is more important .... then look into a less aggressive set of mods .....
It's your car .... make it what is "right" for you.
Just remember ... no matter what you do .... you're driving a Corvette ... and there are BILLIONS of people on this planet who will never have the privelage.
Old Jul 9, 2008 | 10:52 PM
  #66
Millenium Z06's Avatar
Millenium Z06
Moderator
The fronts are $64 from Autozone
It does show a different part number front to rear too. The fronts show to be a 4 wire heated and the rears are 2 wire non-heated. How do you get the fronts to heat up if you are using the rear O2's? You're missing 2 wires and I guess a heating element.
Old Jul 9, 2008 | 11:07 PM
  #67
XtremeVette
Default hmmmm
well just checked autozone....not sure where your info came from?
Here is what i got:
Bosch / Oxygen Sensor
Warranty - 1 YR
13111
$69.99
Application:
Sensor located after catalytic converter
Note:
O.E. type
Exact fit; two required, one per exhaust pipe/manifold; Length (sealing surface to end of connector): 50.5"
Warranty - 1 YR
15703
$52.99
Application:
Sensor located before catalytic converter
Note:
O.E. type
4 wire; heated; 2 required.
I double checked as autozone did not list if the rear was 2 or 4 wire heated. Advance auto has the same sensor....its a heated 4 wire.
So now I will just have to see what is on my car before I purchase new.
Old Jul 9, 2008 | 11:17 PM
  #68
tsts's Avatar
tsts
Originally Posted by road pilot
ARH
Actually, it appears I'll be going to ECS, a short distance away. The responding members have made this a terrific thread with what I think is/was an indepth look into the 02 & codes problems with LT's.
Thanks to ALL.
Old Jul 9, 2008 | 11:48 PM
  #69
jbauch357's Avatar
jbauch357
My Dynatech's with cats and x-pipe were fine for about 3 weeks before they threw a code - got the rear O2's tuned out shortly after...
Old Jul 10, 2008 | 01:05 AM
  #70
Millenium Z06
Moderator
Here is what i got:
Warranty - 1 YR
13111
$69.99
Application:
Note:
O.E. type
Warranty - 1 YR
15703
$52.99
Application:
Note:
O.E. type
When I looked it up with my zip that's what it came up with at he store.
Prices are different too. Bosch site has them and the pic shows 4 wires, wonder why AZ calls them 2 wire, hmmm.
Connector is different though, I have a spare set and the fronts are flat, the rears are square.
For a $100 I'd go ahead and change yours, at least you can eliminate them as a possible problem.
Old Jul 10, 2008 | 01:18 AM
  #71
Millenium Z06
Moderator
They also have a 13450 rear O2 that shows 67" end to end if the 13111 is too short.
About this product:
Part Number: 13450
Weight: 0.45 lbs.
Warranty: 1 YR
Application: Sensor located after catalytic converter
Note: O.E. type
Alternate fit (Customer choice); two required one per exhaust pipe/manifold; Length (sealing surface to end of connector): 67.25"
Old Jul 10, 2008 | 01:22 AM
  #72
gpracer1's Avatar
gpracer1
I thought they are both 4 wire heated. The rears are supposedly higher wattage, thats why you adapt them to the front.
Old Jul 10, 2008 | 12:14 PM
  #73
Mike Mercury's Avatar
Mike Mercury
the rears have healthier heaters.
