Make a coupe beat C5Z
Old Jul 8, 2008 | 12:31 AM
SearayC5's Avatar
SearayC5
Default Make a coupe beat C5Z
What mods and at what price would it take a stock 6 speed coupe beat the Z06 on the quarter mile and in 0-60 times? Also what suspension parts would have to be upgraded? But just in a reliable manner what would it take to make the coupe beat a Z? I want both methods as in:
1. Putting the LS6 parts into the LS1
2. Doing other mods just to beat the Z.
Thanks.
Old Jul 8, 2008 | 01:38 AM
Goody's Avatar
Goody
C5 or C6 Z06?
You don't need suspension work to beat a Z06 in the quarter mile or 0-60 run.
Assume the C5:
You need a bit more than 60hp and maybe a rear gear swap.
Cheapest.......100 shot of N20.
FI..........$5K to $15K
NA.........Long tubes, CAI, LS6 intake, cam, tune
Driver training because a dead even equipment situation will give the win to the better driver. Maybe the Z is modded as well and then you are back to needing more power.
Old Jul 8, 2008 | 09:00 AM
11sec_C5Z51's Avatar
11sec_C5Z51
When my '02 C5 MN6 coupe had just Longtubes, catback, x pipe, CAI, patriot 226cam and tune I was running dead even with a BONE STOCK all the way down to paper filter '04 C5Z.
Old Jul 8, 2008 | 09:48 AM
AFTRBRNR's Avatar
AFTRBRNR
I have the N/A works on my 01'. A C5Z has a snowball's chance in hell of beating me and a C6Z can't get away from me.
Heads
Cam (238/244)
CAI
Longtubes w/X-pipe
Cat-back
Intake w/throttle body
3.73 gears
3200 converter
shift kit
tune
Old Jul 8, 2008 | 10:21 AM
NassyVette's Avatar
NassyVette
What the Z has that you don't is better flowing heads, larger camshaft, different intake, steeper gearing, lighter weight. Do your best to improve all those aspects on your car and you'll gain on a Z.
Rather than upgrading to just Z06 heads and cam, spend a few bucks extra for a set of ported heads ~$1000.00, larger cam ~$350, lifters $100, LS6 intake ~$300, long tubes ~$500 - $1500, and if you wanna get really fancy a set of 4.10's.
Old Jul 8, 2008 | 10:33 AM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
Heads
Cam (238/244)
CAI
Longtubes w/X-pipe
Cat-back
3.73 gears
3200 converter
shift kit
tune
Very nice
Old Jul 8, 2008 | 11:02 AM
blu00rdstr's Avatar
blu00rdstr
You just know the C6Z owner will add a mod or two, and next you're posting questions on the FI section.
Old Jul 8, 2008 | 11:20 AM
1slowFRC's Avatar
1slowFRC
I would suggest N20 and ECS Paxton then smoke both the C5z and C6z
Old Jul 8, 2008 | 12:01 PM
AU N EGL's Avatar
AU N EGL
What year C5 Coupe? if it is before 2002, then you have the LS1 block. if it 2002 or newer then you have a LS6 block. IRC.
The block does not provide more power, but does provide better oiling gallies and better coolant chambers. So you need an LS6 block to start with.
Next some 243 heads and better cam. other bolt on well help, LTs, better exhausts, better intake
Put on the O4 Z06 suspension is a must.
Plus loosing 100 lbs of wt out of the coupe is a huge plus.
The MN6 trans is a better gear ratio then the MN12 of the Z. Lots of guys take out the MN12 and put in the MN6 for that reason.
But since you are looking for 0-60 times, then the MN12 trans is needed.
Good Luck on your project
Old Jul 8, 2008 | 12:27 PM
AFTRBRNR's Avatar
AFTRBRNR
Been thinking about juice but the car is faster and nicer sounding than anything out there so maybe not.
Old Jul 8, 2008 | 12:29 PM
black98c5's Avatar
black98c5
CAI/Cam/LT's/Gears...will do the trick. Or, get a used Supercharger in the parts for sale section and beat a C6Z
Old Jul 8, 2008 | 12:51 PM
99C5JA1's Avatar
99C5JA1
There's no reason to change blocks. The LS1 block has been used in countless high power applications and does fine.
To beat a Z06 in a straight line, a small aftermarket cam (TR224), headers, and 4.10's would be enough. As others have stated, the M6 has better ratio spacing so I would not swap in an M12. While the M12 1st gear may help with 0-60 times, it will make it harder to maintain traction as power levels increase (due to it being a very low gear). And the M6+4.10 will make for a better overall combination for the 1/4 mile.
Handling wise it depends on what you're starting out with. If you have a Z51 car then endlinks, shocks, and non runflats will make you competitive with a Z06. If you have the standard suspension, then you will need springs, bars, shocks and non runflats. I would suggest going with an aftermarket sway bar set and a good set of aftermarket shocks, like Bilsteins. These will out perform the Z06 pieces.
Old Jul 8, 2008 | 01:08 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Here you go - if oyu are going to beat on them you might as well crush them
FI - ECS S/C kit will put you there
http://www.eastcoastsupercharging.com/SC600.html
NA - ECS Custom Cam with Trick Flow heads.
http://www.eastcoastsupercharging.com/CamandHeads.html
To Make a coupe beat C5Z
