Squeaking
Old Aug 1, 2008 | 01:54 PM
rscape2's Avatar
rscape2
I had the same problem, squeaks coming from the right rear. I put new shocks on last winter, so my 1st thought was shocks. I got my brother to push down on the car to make it squeak , grabbed the shock and the squeaking stopped. I then pulled the shock and tightened it up, put it back in, no more squeak.
Old Aug 12, 2008 | 01:07 PM
kas61's Avatar
kas61
I got the outer tie rods replaced and greased everything I could and still have the creaking. I have to take it in for an alignment maybe they can find out what it is.
Old Aug 12, 2008 | 02:44 PM
rare-72's Avatar
rare-72
I've done sway bar bushings and end links. Still squeaks! New shocks are next....
Old Aug 12, 2008 | 03:02 PM
redrckt97's Avatar
redrckt97
Default Sway bar Bushings
I had the same issue, especially when the car was hot. After
reading on this forum, unbolted and lubed the sway bar bushings
(very easy to do) and No more squawking. Thanks forum members!
Old Aug 12, 2008 | 05:49 PM
joe_121212's Avatar
joe_121212
I unbolted the front sway bar bushings, greased them and put them back. The creaking stopped. I did notice that the sway bar area that contacts the rubber bushings had a rough surface like the powder coat had chipped off and caused the squeak. The other side of the sway bar was smooth and did not squeak.
Old Aug 12, 2008 | 05:55 PM
Calibur45's Avatar
Calibur45
Great information guys! Thanks so much for posting
Old Aug 13, 2008 | 11:23 AM
kas61's Avatar
kas61
After greasing everything in sight and changing my bad tie rod I still had the creaking, The last thing I checked was the ball joint. The lower ball joint had some up and down movement so I checked to see if the nut was loose and got about two turns out of it. Took the car for a ride and creaking is gone.
Old Aug 13, 2008 | 03:05 PM
Sinister-one's Avatar
Sinister-one
Front or rear ball joints ??
Old Aug 13, 2008 | 07:19 PM
kas61's Avatar
kas61
It was the left front lower ball joint.
Old Aug 14, 2008 | 09:54 AM
Sinister-one
but the squeaking on most of the cars here in this thread is in the rear of the car.
Old Aug 14, 2008 | 11:45 AM
kas61's Avatar
kas61
Im just trying to help there are ball joints, sway bar, tie rods in the rear of the car.
