Squeaking
Old Jul 8, 2008 | 02:39 PM
Calibur45's Avatar
Calibur45
Default Squeaking
Lately every time i go over a speed bump or hit any sort of dip in the road etc. the car makes a squeaking noise. I've notice my shocks are somewhat looser than they probably should be as well. Is there a way to stop that noise and also tighten the shock?
Thanks,
Old Jul 8, 2008 | 03:46 PM
RBChallenger's Avatar
RBChallenger
Is it from the rear, sounds like a dang bird in the trunk/hatch area? If so I'm told it is the sway bar bushing that need to be lubed.. I have to get under there and try this myself to see if it actually removes the percieved wildlife from my trunk
Old Jul 8, 2008 | 03:58 PM
Calibur45's Avatar
Calibur45
Yes, it sounds something like that, but it also comes from the front as well. I just raised the car this past weekend (it was down to bushings in the front and to 3 threads in the back and that was too low for me now...so i added about 7/16 to both front and back). Could i have done something to cause this ?
Old Jul 8, 2008 | 05:10 PM
Calibur45's Avatar
Calibur45
BUMP
Old Jul 8, 2008 | 05:54 PM
Sinister-one's Avatar
Sinister-one
I have the same problem with the squeaking noise in the rear. I'm thinking sway bar bushings are the problem.
Old Jul 8, 2008 | 11:06 PM
kas61's Avatar
kas61
Same problem but i have lubed the sway bar bushings and replaced shocks and still have the squeaking not sure what to try next.
Old Jul 9, 2008 | 09:39 AM
Calibur45's Avatar
Calibur45
and neither of those worked??
It drives me crazy...i hope we can find a fix for this.
Old Jul 9, 2008 | 11:21 AM
kas61's Avatar
kas61
Did some more searching and think my next step will be replacing the sway bar bushings.
Old Jul 9, 2008 | 11:38 AM
Calibur45's Avatar
Calibur45
Let me know if it works. I would very much like to be rid of the noises.
Old Jul 9, 2008 | 11:39 AM
JJ 86's Avatar
JJ 86
Old Jul 9, 2008 | 11:46 AM
danl72's Avatar
danl72
Hope you figure it out. I would like to know the fix for this as well.
Old Jul 9, 2008 | 01:32 PM
jochumr's Avatar
jochumr
St. Jude Donor '10
Thanks,
If the shock rubber bushings are loose they will sqeek like the dickens. I have the same issue and was about to see if I could squit some grease in there, also the sway bar bushings can always use some lube.
Old Jul 9, 2008 | 02:18 PM
RBChallenger
Glad to hear I'm not the only one. I raelly need to get the car up and lube the sway bar bushings and see how that does. If not I guess I'll revert to replacing them as well... would be nice to actually isolate the noise and not waste a bunch of $$$ on chasing stuff.
Old Jul 21, 2008 | 03:13 PM
kas61's Avatar
kas61
Replaced my sway bar bushing today but have not had chance to take it for a ride yet. I will let you know if the new bushings helped after I take it for a spin.
Old Jul 21, 2008 | 04:10 PM
RBChallenger
I found my bird in the trunk... turned out to be a broken exhaust hanger. Odd that it doesnt rattle but just squeeks.. food for thought for you guys anyways.
Old Jul 21, 2008 | 06:54 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
vote for sway bar bushings.
Old Jul 22, 2008 | 04:07 PM
kas61's Avatar
kas61
Took the car for a ride and still have the creaking sound when I brake and the car comes to a stop, so I will keep searching.
To Squeaking
Old Jul 22, 2008 | 06:12 PM
Jackal's Avatar
Jackal
I think it is the A-arm bushings that need the lube if you have taken care of the swaybar bushings.
Old Jul 31, 2008 | 02:15 PM
nightman06's Avatar
nightman06
Just installed new Bilsteins and am getting crazy squeaking from the rear two. I dont think its the sway bar because it didnt do it until the install. I may have left the rubber bushings too loose on the shocks. Is it safe to use Deep Creep and/WD-40 on rubber bushings???
Old Aug 1, 2008 | 10:30 AM
kas61's Avatar
kas61
I found some play in my drivers side wheel, looks like I may have a outer tie rod going bad. Not sure if that would make a creaking sound or not. I plan on replacing both outer tie rods and will see if the creaking goes away.
