Bleeding new brakes
Old Jul 9, 2008 | 10:28 AM
mtm87tx's Avatar
mtm87tx
Default Bleeding new brakes
im putting C6 Z06 calipers on the front of my car and i wanted to know if there was anything special i needed to know about bleeding these or if i should put speed bleeders on them? do i HAVE to have a VAC or something that creates pressure to do this
Old Jul 9, 2008 | 10:52 AM
TEXHAWK0's Avatar
TEXHAWK0
I still prefer the old fashioned way. Get a friend to sit in the car and hold the brake pedal down while you open the bleeder valve. Use a clear plastic tube from the bleeder to a bottle so you can see if any air is present and if the fluid looks clean. I would go ahead and flush the system until you get clean fluid at each caliper.
Not much room for error.
Other methods, there is more a chance of drawing air back in the system, or spraying brake fluid all over your paint.
Old Jul 9, 2008 | 11:09 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Supposed to be done with a Tech2 and includes exercising the EBCM. BlackZ06 mentioned this not long ago.
Old Jul 9, 2008 | 11:23 AM
mtm87tx's Avatar
mtm87tx
i think my plan is to pump the brakes but use speed bleeders for easy bleeding
anyone know where i can get them?
Old Jul 9, 2008 | 12:12 PM
BlackZ06's Avatar
BlackZ06
You would only need the Tech2 if you get air into the Brake Pressure Modulation Valve (BPMV). So long as the OP keeps his reservoir for the master cylinder topped up, he won't need the Tech2. If he removes the calipers and allows the brake fluid to drain from the reservoir out the disconnected brake lines ... then he will definately need a Tech2.
Old Jul 9, 2008 | 03:36 PM
Bill Dearborn's Avatar
Bill Dearborn
Since the C6Z calipers are 6 piston units with pistons on both sides of the rotor you need to bleed the caliper halves in the correct sequence. The outer half is bled first followed by the inner half.
If you have a helper you can use the old pump and hold method to bleed these calipers. No need for speed bleeders especially if you aren't going to be any brake work for a year or so. You should bleed the system at least once every two years as part of normal maintenance.
Bill
Old Jul 9, 2008 | 03:44 PM
Fast one's Avatar
Fast one
What is a Tech2?
Old Jul 9, 2008 | 06:39 PM
BlackZ06's Avatar
BlackZ06
Originally Posted by Fast one
What is a Tech2?
The Tech2 is a hand held computer that can be connected to GM vehicles for diagnosing and repairing the vehicle. It can read data from the computers in GM cars, can command on/off various functions in the car for diagnostic/repair purposes (such as commanding the BPMV to run to bleed the brake fluid in it), and can be used to reprogram and update the computers in a GM car. Note I say GM, a Tech2 will work on a Chevy, a Cadillac, a Saturn, pretty much any GM vehicle with OBD2, and also works with most OBD1 GM vehicles. I can't imagine there is a GM dealer in the world that doesn't have at least one, large dealerships will have several. Some non-GM service centers have them, and there are individuals who own them also.
The Tech2 was originally made for GM by Vertronix, but that company was bought out and the German company Bosch now is the maker ....
http://www.boschdiagnostics.com/TEST...ges/Tech2.aspx
Old Jul 9, 2008 | 08:58 PM
Goody's Avatar
Goody
You can get used ones on Ebay for a few grand. Ouch
Old Jul 9, 2008 | 09:22 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Where is the BPMV located?
(I prefer the two man method myself for bleeding.)
Old Jul 9, 2008 | 10:07 PM
BlackZ06's Avatar
BlackZ06
Open up the engine compartment .... driver's side ..... at the front of the engine, down low, you'll see what looks like an aluminum "block" with steel brake lines coming out of the top. The lines have different colors of paint daubed on them and the BPMV that the factory folks use to get the right line in the right hole.
Attached to the right side of the BPMV (as viewed from behind) is the EBCM. They are bolted together so that it looks like one unit.
The EBCM is the computer that controls functions such as ABS, Traction Control, and even Magnasteer. The EBCM commands the BPMV by controlling power to the pump, and using solenoids to open and close valves within the BPMV to modulate brake pressure to each caliper, as needed.
On early C5s the EBCM/BPMV are located in the rear of the car ... almost next to the differential ..... IIRC it was sometime in the 1998 year that the system moved to the engine compartment.
Old Jul 10, 2008 | 12:37 AM
USA C5's Avatar
USA C5
Default Brake Bleeder
Older style EMS style suction units work great for changing or bleeding your brake fluid. I use a unit like this:
http://cgi.ebay.com/NEW-Impact-Sucti...3286.m20.l1116
In my 2000 I use Motorcraft Dot 3, it has the hightest boiling point of any Dot 3. Start by sucking out most of the old fluid from the master cyl. and replace it with new. Always use freashly opened brake fluid. You will need a double christmass tree adaptor (less than a buck from any EMS supply catalog) to adapt the suction hose to the correct size I.D. fuel hose needed to fit snugly over the wheel cyl. bleeder valve. Then start sucking, first from the Right Rear, until clear (while a freind keeps the master cyl topped off). Move to the Left Rear, than the Right Front, than the Left Front. Be carefull not to build up too much pressure or the collection cannister will crack, about 450 mm/Hg is plenty (buy one like the impact with a adjustable manifold pressure). Good luck.
Old Jul 10, 2008 | 12:49 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Thanks,
thought it was in there somewhere but didnt mess with any that stuff when I removed my MC and bled the lines. (The fluid in there was dis-gus-ting!!!!)
Old Jul 10, 2008 | 08:00 PM
TEXHAWK0's Avatar
TEXHAWK0
I think the EBCM circuits are normally closed, so you should be able to manually bleed the brakes without opening the circuits with a TECH 2.
I replaced the master cylinder on my car, and flushed the whole system, and the brakes are as firm as ever.
Old Jul 10, 2008 | 08:24 PM
Greg_E's Avatar
Greg_E
Reply deleted. I did not notice that the OP's calipers were C6 Z06 calipers.
To Bleeding new brakes
