Help with wiring
Old Jul 11, 2008 | 05:33 PM
jski0236's Avatar
jski0236
Default Help with wiring
Well,
I think I might have found something that could be related to my PCM 0410 code but am unsure of where this connection goes or what it is for.
In checking the air pump, vacuum hoses, etc I found a cut connection on the passenger side at the front of the car. It is a 2 wire plug that is attached to the fan shroud on the passenger side. At this time nothing is plugged in to this and I did find 2 cut wires about 4-5 inchs away from this plug. I checked the service manual and can't find what this plug is for. Should something plug into this? If so, what does this wire control?
I added the pic as my aviator of what I found.
