my vette, 99 coupe drinks oil pretty rapidly, 1qt every 2k miles. It never had this problem until after 55k miles, I now have 75k. I put a small ofiface pcv valve on and didnt notice much difference. I had a comp. test done for the rings and they all checked out great at 150. It was suggested that i look into replacing the valve stem seals .
I realize that all vettes drink/burn oil to one extent or another, and I am also in the process of installing a catch can too.
Any idea whats involved in replacing the valve stem seals, and what can I expect to pay??? and im not planing on going to the stealership to have this done.
thanks
thanks
75K miles and your using 1 quart every 2k miles ??????
That is TOTALLY NORMAL oil consumption ..... unlax ...... GM's "rule of thumb" for an "oil burner" is 1 quart every 1k miles (or worse) for an LSx engine .....
You're fine, just watch your oil levels and you have nothing to worry about.
I dont think thats TOTALLY NORMAL, there any may owners who have no missing oil issues, and if there's something i can do to to fix it , I will. thats just not right to use that much oil. Car is a daily driver. while im in there I think I will upgrade to the L6 valley tray pcv system.
Your car .... do what you want .... but there are many people having to add a quart or two between oil changes ...... and the GM "rule of thumb" applied when in 2001 owners were complaining of "oil burners"
... so yeah .... an all aluminum engine with 75k miles ... one quart per 2k miles is not abnormal.
Why are you suspecting the Valve seal? I don't have any experience with replacements, but I think with valve seal wear you would start to get a puff of white/blue exhaust at start up.
Others that know comment.
As far as oil consumption was this a step change in haigher consumption rate or has it been gradully getting worse. Any other changes that might point to a root cause?
seals are easy. Around $35 in seals and it will take a mechanic that is familiar with the LS1 about 2 hours at the most with the right valve spring tool...
Originally Posted by vettenuts
From a forum vendor, the seals are about $35 last I knew. If you have the tools, its an easy job.
With an air compressor, a spark plug adapter and a spring compression tool, it is fairly easy. The only bit of hassle I had was my choice of spring compressors. The one I bought was not the cheapest but it was not the fancy two-spring-at-once version that's kinda expensive.
BTW, I used a 1/4" drive 12mm 6 point deep socket for pushing on the new seals by hand instead of buying a $30 seal installer tool. Just make sure the socket is evenly sitting on the seal (all the way around) before giving it a good push. They went into place fine for me with no damage to the seals at all.
Im suspecting the valve seals because when I nail it getting on the freeway, Im sending a smoke screen out the pipes.
have not noticed puff at start up, but there is black marks on the floor of the garage under tailpipes.
Originally Posted by gfunk
thanks for all the replies.
did a compression test and all checked out fine.
I think I will bump up to thicker oil too.
any other suggestions, im all ears
One thing you might keep in mind too is the (good) rule-of-thumb about "smoke" i.e. if it shows up under acceleration it's usually rings, but if it shows up under deceleration, it's usually valve guides and/or seals. The amount of manifold vacuum being the obvious difference.
BTW, what do your plugs look like? One other thought too, have you looked at checked your A/F ratios?
I also get black soot on the rear.
what should A/F ratio be at?
if its out, is something like that adjuted??? or?
Black residue/soot on the rear could easily be A/F related. It can be checked and/or adjusted by a good tuner.
Oh, regarding your question "should be".......A/F ratio will vary somewhat depending on several factors, i.e. temps, rpm, engine load, throttle position, open loop/closed loop operation, etc. That's just one reason why a good tuner can be worth their weight in gold in getting your car running at it's best, barring any mechanical problems of ocurse.
HTH
Reason: added info.
When the valve seals got hard and started letting oil, lots of it by in my '88 Dodge mini van, (twice in 230,000 miles), it would smoke blue when warm and idling, and then leave lots of blue smoke when pulling away from a dead stop. Was burning over a qt. to 500 miles, and then I insalled new valve seals, and no more smoking, no more oil burning. Needed new valve seals every 90,000 miles!
Sounds like you also may have had valve guide wear issues as well as the seals. That fact plus really good oiling ( ) in the valve covers must have been letting a bunch of oil into the combustion chambers during idle (high manifold vacuum). I'll bet that thing REALLY was a "fogger" on extended deceleration.
gfunk: Sounds like you may benefit from a good catch can as well as a Watts filter (PM Dave68 for info) too. Even if they don't stop actual oil "usage", they keep all that stuff from turning the inside of your intake manifold into an oily "swimming pool".
I came across this thread in searching valve seals. I will be replacing my valve springs and rocker arms and from what I read might as well throw in the valve seals at the time.
LonestarFRC, says to use a 12 mm 6 point deep socket to push the seals in. Sounds simple enough but tell me how do you prepare for the installation. Meaning is there an old seal that must be fished out?
Thanks for any help you can offer,
Jay B
That guy is smoking crack... Should be a max of $225-$300
That guy is smoking crack. They are getting desperate these days and still think its ok to rape a customer. To find a good deal on my clutch install I had to go 3 hours out of my way but then again....I liked Pavlock so much that I ended up with a new 402, hardened trans and hardened diff! So he got all my money just for being reasonable unlike some of the local Vette places looking for a rape job without even enough courtesy as to even spit on the hole!
Hahahahahaha to you over priced bitches.
Flame on
Jay B
Your car, being a 2000, will have the umbrella type seal with a separate seat for the valve spring. Old ones can be removed with a pair of pliers. New ones are pressed on and there is a measurement in the manual that is taken to ensure they are in place correctly.
