Can someone give me some instructions on how to remove the outside rearview unit. I am trying to run some led turn signal wires through the door and into the mirror.
Start with this, http://forums.corvetteforum.com/show....php?t=1606865
It will show you how to remove the door panel. Then, if memory serves me, there are two screws that you have to access through one of the holes in the door. It requires a star driver. There is also a wiring connector you have to disconnect as well. Good luck.....
