HEEELLPP!!!! Drove through some deep water....
NEVER drive a Corvette through "deep" water ..... you always have the option to park it and get it towed.
Do you have a modified engine intake (such as a Vararam) ???? Even the stock intake is located low in the nose of the car. There is a significant chance you have hydro-locked the engine.
I would IMMEDIATELY do the following .......
Remove all 8 spark plugs
Turn the engine over BY HAND. Notice if you feel any points where you feel (or hear) any significant resistance to being turned over. If in doubt .... tow the car to a good mechanic.
Inspect for water having come out of some cylinders.
If no water came out .... BEFORE replacing the spark plugs, try turning over the engine with the starter motor.
If water came out .... unless you're mechanically inclined, I'd stop there and have the car towed to a good mechanic.
If cranking with the starter now seems to be OK .... put the plugs back in and try starting the engine ..... LISTEN for any unusual noises .... if in doubt .... tow it .....
If the starter still isn't working you could try removing it and drying it out, or replacing it. Replacement may be the best option.
Corvettes were not made to go through anything deeper than a puddle. The intake system was designed to handle rain and splashed water from puddles, not a semi-submerged drive through deep water. The starter is low and has positive contacts that aren't designed to be submerged.
At best you probably fried the starter motor. At worst a hydro-lock could have severly damaged the engine. If in doubt .... tow the car to a good mechanic.
Good luck,
If you hear the starter spinning, it may not be engaging the flywheel as you suspected.
I would NOT try the starter any further ..... at best, after you remove the plugs, turn the engine over using a large wrench on the crankshaft. IF the engine turns over a few times with no obvious noises or binding, then post again and we can give you more info.
From your description of the amount of water in the intake, and the starter being unable to turn the engine .... you're probably looking at an engine teardown/replacement.
For your next car, try reading the Owner's Manual ...... The Section entitled "Driving in Rain and on Wet Roads" has a warning against doing what you did.
Again, good luck, I suspect you're going to need it.
Here's one.
http://forums.corvetteforum.com/show...rolocked+motor
Starter ended up being toast (broke one of the mount holes so it wouldn't engage the flywheel). After they replaced the starter, the only other problem was that the Throttle Position Sensor had some water in it and was dead. Chained oil and the TPS and it has worked great ever since. Probably the reason I didn't have internal engine damage is because I have forged internals.
Insurance never balked at my aftermarket aircleaner, supercharger, additional fees for changing the starter due to Long Tube Headers. It was all covered under my comprehensive portion of the policy with NO deductible.
It was a pain to go through but it all worked out in the end. Good luck with yours.
That sucks....! Hope your insurance company handles it...
