When Air Comes Out of All AC Vents - A How To Fix Write Up with Pics!
#121
Well, if you cannot feel it with your hand, or see it with an inspection mirror....then it can be easily evaluated at the reservoir.
#122
Roger that! How is it that you became a "Tech Contributor" anyway? I just really need to take care of it already...been too dang lazy.
#125
Thanks,Matt
#127
#128
fitting on the back of the manifold was blocked providing no vacuum. The vacuum line was also clogged, so I ran a by-pass hose from the manifold fitting once I cleaned it out with brake cleaner and compressed air.
#129
Success! Great thread. A member posted this link to me and it was a great help. I found both of the hard plastic lines broken in 4 total places due to the dreaded acid leak. It looks like the battery acid issue was a long time ago so no telling how long this has been malfunctioning. I did cheat a bit and just sleeved the lines with a thick wall vacum line but it seems to work fine. It was cool to get the tell tale sign of a little dust puffing from the vents. No issue at the manifold or the fender area with the canister/check valve.
bigthaw (11-15-2018)
#130
I've been having the same problems for two years now, ever since I swapped in an LS3 motor. I checked all the lines under the battery tray, but everything looked practically brand new, no signs of any acid leaks. Then I tried to check the attachment at the manifold, but couldn't see a thing, even after removing the coil bracket, because I have a Lingenfelter reluctor wheel adaptor mounted on the firewall, and all the wires going to it have a split loom sleeve on and completely block my view! I did remember that I made an access panel above the oil pressure sending unit though, so I took the windshield wipers and the shroud under them off, and sure enough I could see the nipple. There was a split on it, so I figured that may be it and I could just snip that off and reattach. Well, when I pulled it off the nipple, the whole line came out, and I was staring at a 4 inch piece of rubber hose. Sooooo, I think I found the problem. LOL. I can't see any of the hard line down in there, so I think I'm going to bypass it and run a rubber line down to the battery area and splice into the hard line there.
#132
My photo's are public, here is the link: everything is pretty much shot in order -
http://s83.photobucket.com/user/madm...?sort=3&page=1
Thanks,Matt
661-406-7516 (call or text if needed)
#133
You know what's weird, I think you have another post here on the forum with the same information, and in that thread, the pictures are visible. Very weird. I think I had the same thing happen, my batter started leaking acid, and I'm betting it ate away that line below the battery box, as I had to clean acid up from there before. Do you think that it's possible to just splice in a new part of line with a male to male connector, instead of replacing everything?
#134
Either way give it a shot and let us know what happens.
Thanks, Matt
#135
Thanks to all the posts from you nice people I fixed my AC today.
Cold air is blowing in the car again.
I replaced pieces of all three black lines to the check valve.
Many thanks!!!!
Many thanks!!!!
#136
Late to the show here! Help
Just love the Forum as a resource for Corvette fixes. I have the same issue with low air from all vents on my 2000 C5. Here's what I know so far. I have accessed the vacuum tank behind the right fender by partially removing the fender. I have confirmed that no acid issues exist. A few years ago, I changed my oil sender unit via removing the IM. At that time, I placed an extension line to the small vacuum port from behind the IM. Today, I have also confirmed via my Mighty Vac, I have 6 psi at the vacuum tank. So that's a good thing. I placed an adapter to temporarily connect the good vacuum line to the line going up to the firewall, which in turn gave the controller 6psi, I guess. I thought that this would produce favorable results at the vents, but I got no change. Air is still blowing out of the defroster, eye level and lower vents. This obviously did not fix my issue. I would greatly appreciate any input now. Since I am 66 years old, most of my bending, twisting and keeling days are behind me, but I refuse to give up. Does anyone feel that I need to remove the a/c controller? I did remove it once when I repaired the low illumination issue by successfully re-soldering the factory welds. That was at least 4 years ago and I would think that if I have somehow mis-aligned something, it would have shown up sooner. This vent air issue is less than 3 months old.
#138
I had the same problem I had to change my Cam Positioning Sensor and to do so you have to remove the manifold intake. I did not replace that vacuum line after putting it all back together. I did not even realize that there was a vacuum line back there to reattach. Well I had the same symptoms air blowing through all the vents and a P0410 code popped up. I tested the vacuum lines and none would hold a vacuum so to be a 100% certain the line was not attached I blew cigar smoke in the main vacuum line and my friend seen that smoke from the rear of the manifold. I wanted to be so sure that was the problem before removing the manifold intake. After disassembling all the components (PITA) i only moved the manifold forward just enough to work back there and sure enough I found the line was unattached with really no room to reattached it,.so I purchased some 5/32 line and a few splicers and lengthened it considerably put it all back together and AMEN the A/C vents responded as they were designed to and there was ample vacuum at the secondary air pump. I tried and tried even cut the back of my hand trying to feel the unattached line behind the intake manifold I really was not looking forward to removing that manifold intake again but I had no choice but was successful in doing so. Thanks for the post it helped immensely. My Corvette is an 02 convertible
Last edited by Marco 1976; 05-21-2022 at 02:51 PM. Reason: want to add more information
