ok.....got the 416 in..ready to fire up...but had to bleed the clutch first as i broke the housing of the slave on instal. so, put another one in...
filled up the resivour...tried to bleed it for 20 minutes. took the fluid..its coming out of the bleeder. not leaking anywhere...but pedal falls to floor with 0 pressure...master was 100% before we pulled the 346....WTF could the problem be??
