HELP - Headlight Door Motor Replace
Old Jul 15, 2008 | 07:21 PM
jost6453's Avatar
jost6453
Default HELP - Headlight Door Motor Replace
The driver's side headlight door motor seems to have crapped out on my '02 coupe. Can anyone offer some advice on how to replace it? I see two bolts with nuts on the back side and a third that I can't tell if there is a nut ... or not. It's pretty much burried. Do I need to take the entire door assembly apart? Looks like a big job for what should be a minor repair.
Old Jul 16, 2008 | 02:16 PM
DashingDaryl's Avatar
DashingDaryl
I have done it before, but it was awhile back...
Off the top of my head I would say:
put your car up on ramps.
Manually raise your headlight
Take the Plastic Bezel off the Headlight
Remove the Plastic Panel on the underside of your car so you can access the assembly from underneath the car.
If at all possible trace the mount with a grease pencil or crayon so you don't have to realign the assembly upon installation.
Remove the 4 or 5 bolts that secure it to the frame.
Lift out the entire assembly and then exchange the motor.
Reverse the proccess
Old Jul 16, 2008 | 07:54 PM
Oldvetter's Avatar
Oldvetter
How do you know it is the motor? The gears usually go bad. Can you hear noise? Do a search.
Old Jul 16, 2008 | 08:10 PM
jost6453's Avatar
jost6453
The door won't open, - no noise. When I use the maunal open ****, open it part way, close again, then try the headlight switch, it seems to work OK. It's intermitent. Not the gears.
Old Jul 16, 2008 | 08:23 PM
bgray's Avatar
bgray
It's not a big job at all. I went to the metal gears on both of mine a few months back. One of mine went. I did one and found it was so easy I pulled the other while I was at it. This is the thread that helped me. couldn't get much easier with information like this. You may not be changing the gears but the thread walks you through changing the motor as well. Sounds like a gear to me as well but I am no authority on it. Might as well pull it apart while it's out. the stealership wants an insane amount for the assembly. Good Luck!
http://forums.corvetteforum.com/show....php?t=1767764
Old Jul 16, 2008 | 09:42 PM
coxjajb's Avatar
coxjajb
I replaced the gear in mime last week end. Very easy to remove the whole headlight assembly rather than just removing the motor.
http://www.digitalcorvettes.com/foru...d.php?t=102908
Old Jul 20, 2008 | 06:48 AM
Oldvetter's Avatar
Oldvetter
Intermittant raising with no noise is a gear problem.
Here are the stages my bad headlight gear went through:
1) Headlight would not open all the time, you had to try several times.
2) Headlight would rarely open, but if you turned the manual **** a little, it would usually open.
3) Headlight started making a machinegun noise when closing for 5 seconds.
4) Headlight would pop up with just parking lights on.
The headlight module controls opening and closing. It works by sensing the current spike when your headlights hit the open and close stops. BUT, if your gear strips at the opening or closing position, there is no current spike. A timer in the circuit then turns off the motor, but the headlights sometime get out of synch.
Motors RARELY go bad.
Headlight Modules RARELY go bad.
I would bet it is your gear !
Old Jul 21, 2008 | 03:32 PM
Woodstoc's Avatar
Woodstoc
I'm with Oldvetter. Exactly the same symptoms mine is giving me now. I'm just deciding whether to do it myself, or take it in on warranty and dealing with the dealership hassels.
Old Jul 22, 2008 | 07:24 PM
jost6453's Avatar
jost6453
Thanks for the feedback. I guess I'll give it a little more time and see what develops. It sure SEEMS like the motor ... but it won't be the first time I've been wrong.
Old Oct 5, 2008 | 01:45 AM
YELLO C5's Avatar
YELLO C5
I'm in the same boat. No noise. What was the verdict?
Old Oct 5, 2008 | 03:58 AM
DeeGee's Avatar
DeeGee
Gotta say my diagnosis would be the same as the other guys
Heres a diagram that might help you if you do decide to replace it. Its pretty obvious how the thing goes together from the pic:
Old Oct 7, 2008 | 09:45 AM
ejpolitza's Avatar
ejpolitza
I had much the same problem, changed the gear and then still not working turned out to be the control module. Luck had alot to do with it cause I found the part local and quick fix. No grinding noise? Chances are module.
Do a search Junkman had a really good discription of the removal DIY
Ed
Old Oct 7, 2008 | 10:48 AM
B-Vette's Avatar
B-Vette
Let us know how it turns out.
To HELP - Headlight Door Motor Replace
